245/70r19.5 on stock f550 wheels
recycler
thinking of putting 245/70r19.5 on my 99 f550 to help cut the gear anybody had any luck runninig them
1999 F550 truck conversion
6 REPLIES 6
recycler
I would love to swap gears, but I haven't been able to find a used center sections for reasonable amount seem to average $950 plus core for the rear end it has. What I really like would be a custom made set of Alcoa 19.5X14 Super single wheels with some retreaded 445/45r19.5 Michelin tires they're around 35in tall. Could always just put a double overdrive Eaton/Fuller 13sp in it.
All_I_could_aff
It's only about a 4% drop in overall ratio. But u do also gain a little weight capacity. Plus they look kind of badass!
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollinโ€™ on 33โ€™s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
blt2ski
Moderator
Moderator
If my figures are correct....you do not drop much. A 4.88 to 4.73 or so. A gear swap in reality might be better option depending upon how much lower you want motor to run at say 60 mph. Along with how tall your highest gear in trans is. a drop to say 4.33's might be better in the long run. Along with the taller tires that I figured was a drop of about 3% vs the 4% in belows post.
Editing this to fix phat thums on smart phone and blankety blank blank auto correct!
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
recycler
All I could afford wrote:
I ran them years ago on my 2001 F550 instead of the 225/70 no problems, I initially test fitted a used set from our a International 4700 that came stock with that size.
What do u mean by "cut"?
the truck has 4:88 gears with a lower redline on the swapped in 5.9 cummins so I want to cut or reduce the gear ratio with larger diameter tires
Bedlam
Moderator
Moderator
The 245's are taller and help ratios if you are geared too low with the 225's. My Ram has the 4.44 gearing instead of the 4.88 for just that reason.
All_I_could_aff
