Oct-13-2017 08:05 AM
Oct-15-2017 03:48 PM
Oct-15-2017 10:10 AM
Oct-14-2017 06:10 PM
dodge guy wrote:
And most breakers aren’t designed to be a switch! Just a circuit interrupter. Constantly tripping it will wear it out resulting in no protection or constant false trips. Not many breakers are switchable!
Oct-14-2017 06:06 PM
Oct-14-2017 04:49 PM
Oct-14-2017 02:58 PM
2oldman wrote:Lynnmor wrote:Of course it is. I've been to one campground (Farewell Bend in OR) where they post a sign saying "Leave Breakers on". I find that weird.
It seems to me that turning off the breaker at the post would be much easier than the way you do it.
Oct-14-2017 01:44 PM
time2roll wrote:Well, that is a surprise to me. Seriously..they don't know that?
Because people too often make the host come out and fix the problem with no power in the RV.
Oct-14-2017 01:35 PM
Lynnmor wrote:dodge guy wrote:
I only encounterd one burnt 30A outlet in a campground. Other 30A outlets were just broken. I too have a 50-30A connector that I use when there is a 50A available.
I never turn the breakers off. If your arcing when plugging in then you have left something on. Mine doesn’t arc. Been doing it this way for years with no issues.
It seems to me that turning off the breaker at the post would be much easier than the way you do it. Opening the breaker panel door and flipping all your breakers off in your RV must be a pain. Of course you already know that is the only way to shut down the converter.
Folks this is why the you have bad connections that burn your plugs.
Oct-14-2017 09:55 AM
2oldman wrote:Because people too often make the host come out and fix the problem with no power in the RV.Lynnmor wrote:Of course it is. I've been to one campground (Farewell Bend in OR) where they post a sign saying "Leave Breakers on". I find that weird.
Oct-14-2017 09:49 AM
Oct-14-2017 09:38 AM
Oct-14-2017 09:14 AM
D.E.Bishop wrote:OP said he was running a 20a socket adapter at the house.
The following is a quote from 2oldman's post, I think I understand what he meant but if he meant using a 30 amp outlet at home is suspect, he is wrong, mine is better than 99 percent of campground outlets."At the house is also suspect if you're running air."
Oct-14-2017 07:14 AM
Oct-14-2017 06:01 AM
