50 Amp to 30 Amp
dtzackus
We are going to a wine fest and the area we are camping has 50 Amp electric service, our rig takes 30 Amp service. If I purchase an adaptor from 50 Amp (male) to 30 Amp (female), will it be ok? I am not sure if the 20 extra amps will harm anything..
Thanks in advance.
Dan, Tammy, Cory, Leah and Adam
2016 Chevy Silverado 2500HD 6.0
2018 Highland Ridge Open Range OF374BHS
GM Integrated Trailer Brake Controller
17 REPLIES 17
wildtoad
You will be fine. You will still be limited to the 30 amps your RV systems are wired for.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
NORM_WADDELL
You R V's input/incoming circuit breaker is rated at 30 Amperes
and will trip if you exceed that
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
mhardin
Amps are watts divided by volts. More available Amps are better. Think of the wall outlets in your home - most are probably on 15 Amp circuits, but you may have a few on 20 Amp circuits. You can run more power hungry appliances on the 20 Amp circuits than on the 15 Amp circuits. As long as you get the proper adaptor, the "extra Amps" won't hurt anything.
Mike
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
