โJun-29-2014 03:16 PM
โAug-01-2014 07:02 AM
โJul-02-2014 06:02 AM
somewhere in the texas 'lost pines'
โJun-30-2014 04:36 PM
โJun-29-2014 07:48 PM
โJun-29-2014 07:25 PM
Gsragtop wrote:
I'm going to try and clear things up.. The front of the units, sucks and blows as it should.. The back of the unit is vented outside the coach and is where the condenser is..
There are however ribbed vents on both sides of the unit (as with all window ac units) and these vents are not open to any real airflowthese vents are not open to any real airflow.. I had assumed the roof vent allows airflow into the box that houses the ac unit.. That is why I was surprised to see no holes for the box to vent out of.
If it helps this is the unit I got
http://www.walmart.com/ip/Whirlpool-High-Efficiency-12-000-BTU-115V-Window-Mounted-Air-Conditioner-with-Remote-Control-ACQ128GPW/25394510
โJun-29-2014 07:16 PM
โJun-29-2014 07:06 PM
โJun-29-2014 06:50 PM
โJun-29-2014 05:26 PM
โJun-29-2014 03:50 PM
โJun-29-2014 03:35 PM
Tequila wrote:
15 amp is probably not enough for a 12000 BTU A/C especially if you are at any altitude. 9200 is about the max for 15 amps. The wiring can catch fire if you use an adapter and plug into 15 amp service. I remember a dealer using a 15 amp adapter on a unit with a 13.5 A/C and stuffing it in the power box. It caught the RV on fire. Some modern RV A/C's will shut down if they cannot draw enough current to run, before the breaker at the other end pops, even. I think that is your problem. As to the venting, You have to vent it somewhere. A/C's produce heat, which is how they cool. Surely it vents outside through the wall.
โJun-29-2014 03:28 PM
