Aug-24-2013 12:20 PM
Aug-24-2013 04:46 PM
NanciL wrote:
Yes it means that it is an 18 foot trailer. I had one - Bought it new.
With the Dexter easy lube bearings, you just remove the rubber cover.
Then jack the wheel off the ground and as you spin it pump grease into the fitting until you see the new grease coming out.
My trailer is now five years old, and I do it once a year.
I always check it for play when it is jacked up.
On each long trip, I check the wheels for heat build up every time I stop for gas
Jack L
Aug-24-2013 03:41 PM
Aug-24-2013 03:27 PM
Aug-24-2013 01:39 PM
Aug-24-2013 12:37 PM
