โFeb-02-2015 10:42 AM
โFeb-03-2015 05:19 PM
โFeb-03-2015 02:08 PM
aamyotte wrote:
The power center usually has some spare spaces available to add circuits. If you use one of the spare spaces you can add a dedicated circuit and fuse size as needed, this would be a shorter run then going to the battery. You wouldn't be trying to add a fuse block and trying to make the connection at the battery. The power center is usually near the floor so that you could run under the trailer to the back.
โFeb-03-2015 06:08 AM
โFeb-02-2015 10:39 PM
ianmac23 wrote:westend wrote:
How many watts does the fridge draw?
4.5amps on 12v and I think the run will be like 32ft
โFeb-02-2015 03:48 PM
โFeb-02-2015 02:12 PM
โFeb-02-2015 01:54 PM
โFeb-02-2015 12:21 PM
