โMay-05-2014 06:19 PM
โMay-19-2014 05:57 PM
artfd wrote:
"The mounts need to be BOLTED to the frame and you need metal tie downs." Metal ties from an underframe belly bar to the eyebolts on a truck camper -- chain, hooks, eye bolts, turnbuckles, all can be found in hardware stores most anywhere in the USA. http://www.etrailer.com/Accessories-and-Parts/Brophy/TDHP.htmlThis kind of hardware.
--- Finding a belly bar if an old one fails or if you need to fasten a truck camper to a pickup bed ASAP, that is another matter. There was no easy or straight forward way I knew of at the time to fasten a wooden beam to the bottom frame members of a pickup truck bed. The metal belly bar I got came with specially fashioned strong brackets that worked very much like U-bolts to keep the belly bar in position.
--- After I tightened those turnbuckles between my camper and my wooden belly bar for the week that I used wood, I detected no evidence of movement or sliding. For the first 20 miles or so I stopped repeatedly & re-tightened the turnbuckles to take the slack that did develop, until there was no further slack. I grant I did not exceed 55 mph and only drove on smooth roads.
โMay-19-2014 12:29 PM
โMay-18-2014 07:59 PM
โMay-17-2014 03:36 PM
โMay-16-2014 01:01 PM
โMay-16-2014 09:12 AM
โMay-15-2014 06:57 PM
okan-star wrote:
If your hitch has open ends , you can slide 2" x 2" x1/4" box into it and drill a hole thru the hitch and the box , put a pin in it so its removeable, drill a hole in the top on the outer end and hook the turnbuckle to it .
That's a cheap rear setup
Like this
โMay-09-2014 10:39 PM
Cymru wrote:
I am looking for a truck camper and tie downs. I have found a few good campers, but tie downs are way overpriced! Does anyone have good ideas on sourcing affordable tie downs? If it makes a difference, the upcoming camper is going onto my 2005, GMC, 2500, diesel, crew. Thanks!
โMay-06-2014 07:53 PM
โMay-06-2014 03:14 PM
โMay-06-2014 12:40 PM
Cymru wrote:
This question will certainly seem redneckish, but why not use ratchet straps?
โMay-06-2014 10:24 AM
โMay-06-2014 04:16 AM
โMay-06-2014 12:16 AM
