Alternative Generator For our campers
brholt
Given the limited space in truck campers and to avoid carrying gas I was wondering what people think about something like this:
Car Based power generator
They seem to have both a "1000" watt and a "2000" watt model though the later is pricy.
48 REPLIES 48
JoeChiOhki
jaycocreek wrote:
Idling Causes Excessive Engine Wear
• Running an engine at low speed (idling) causes twice the
wear on internal parts compared to driving at regular
speeds. According to the American Trucking Association,
such wear can increase maintenance costs by almost
$2,000 per year and shorten the life of the engine.
That's usually why most of the on-engine driven stuff or PTO stuff brings the RPMs of the engine up closer to their road running levels while working :).
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
Geewizard
I had problems with much lower power (much longer cooking times) and a rather disturbing growl from the microwave. It sounded to me like the microwave oven was very strained.
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
Kayteg1
I have digital-control microwave in my 19 years old camper and it works fine with square sine. I think it is less efficient, but might be my imagination.
What problem did you have?
Geewizard
I had a big problem with MSW (modified sine wave) inverters and microwave ovens. That is the sole reason I spend the money on a Xantrex pure sine wave inverter....15 years ago.
Kayteg1
Been using modified sine inverters for 20 years and never had a problem with the sine.
Sure now, when pure sine 6000W peak inverter sells for less than $100, I went for it. The only drawback was lack of remote switch wire, but I open it and solder parallel wires to main switch for remote.
Works like a charm.
Geewizard
ticki2 wrote:
I notice that generator symply says sine wave , not specifying whether it is pure sine wave or modified sine wave . :h
Email (verbatim) from the distributor:
Buffalo Tools
Christina Torres
Mon, Feb 17, 12:47 PM
Good Afternoon ,
Thank you for contacting us regarding your questions on our generators. Our Generators provide Modified sine wave.
If you have any other questions or concerns please feel free to contact me to the information provided below. Thank youfor being a valuied customer hope you have a great rest of your day ??
"What is the difference between a pure sine and modified sine inverter?
Both types of inverter will provide power to AC appliances, however Pure Sine is high quality equal to (or better than) the power in your home, Modified sine wave power is a simpler form of power and is adequate for simple electronics, but may damage more complex ones."
Sincerely, Christina Torres
950 Hoff Rd
Ofallon, MO 63366
Direct Line:1-636-409-1362
Office Line:1-636-532-9888 x217
Fax: 636-537-1055
ppine
Solar with inexpensive gen backup.
With a long cord off your TT, you can leave the gen in the back of your truck and run it with the tailgate down.
NRALIFR
No, no, no.
The inventor of this “generator” says it’s OK to idle your engine for 70 hours straight.
So it’s OK.
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
Riffler
I also prefer using Solar Panels.
jaycocreek
I think if you refer to your owners manual you will see it is not advised to idle your pickup diesel for long periods like over 3-5 minutes if memory serves me..
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
pnichols
Would that information be in reference to gas truck engines or diesel truck engines?
2005 E450 Itasca 24V Class C
jaycocreek
Lance 9.6
500ah Lifep04
Geewizard
And it's not recommended for use over 3000 feet.
ticki2
'68 Avion C-11
'02 GMC DRW D/A flatbed
