May-11-2020 07:06 AM
May-19-2020 09:17 AM
LITEPHIL wrote:
Please explain how the weight,I mean real weight like 500 lbs is transferred onto the front of the vehicle.
May-19-2020 06:48 AM
May-19-2020 06:01 AM
LITEPHIL wrote:
If you understand the basic function of a weight distribution system then you understand the function is to take weight off the rear axle and distribute it onto the front axle of the tow vehicle. The only way to do this is with pretty serious leverage. When you see those large forged spring bars flexing and putting weight onto the front axle you see what kind of force it takes. Those 2 little springs may help with sway control since its trying to keep things straight but will be very ineffective in actually transferring weight to the front of the truck. Pretty hokie set up if you are going to call it a weight distribution set up. That 4 or 5 inches of leverage won't do a thing on a heavier trailer and doubt it would do much on a light trailer. Save your money and get a Reese,a Curt or a 4way system.
May-18-2020 09:28 PM
May-18-2020 07:40 PM
May-18-2020 06:12 PM
May-18-2020 01:34 PM
ajriding wrote:
That is what is called a progressive spring rate. The bars have a more linear spring rate, and a linear spring rate is better in this situation.
I also tend to end up at rough places, dirt roads that get worse near the camping spot, so I have to take the bars off before I get there. The bars are easy as I just use a lever to unload the spring, but the Anderson requires jacking up the tongue?
May-18-2020 09:17 AM
ajriding wrote:
rhat is what is called a progressive spring rate. The bars have a more linear spring rate, and a linear spring rate is better in this situation.
May-18-2020 09:00 AM
ajriding wrote:
....sipI just use a lever to unload the spring, but the Anderson requires jacking up the tongue?
May-18-2020 08:13 AM
djsamuel wrote:
Never had an issue with that over the many places we've gone with the hitch. I would add though, that unlike springs which have a more consistent spring constant, the urethane "springs" resist compression more as they are compressed. So while they may compress easily at the beginning, they become more difficult to compress as the force is increased. I think this is what helps prevent the urethane from "bottoming out".
May-18-2020 06:44 AM
mr_andyj wrote:
The red urathane bumper is the spring, so it does have a spring, a red urathane spring.
For those that have one... How much angle difference between the truck and trailer can be had? The red bumper is short, so the spring travel will be small, and when it bottoms out that is it. With bar springs they will keep bending or the trailer frame will bend, but mostly the spring bar will bend as needed.
Or what happens if you go too far? Will the bolt-on mount just twist forward and no harm other than having to re-set it?
May-18-2020 05:19 AM
May-17-2020 08:38 AM
May-16-2020 08:34 PM
May-15-2020 07:37 PM
