anyone replace a Jensen with a Jack?
iwon415
My new camper came with a Jensen omnidirectional antenna which appears to be worthless. Many posts on the net seem to agree.
Many people have had good luck with the new Jack antenna (always sits up like the Jensen) but is rotatable. Any truck camper switched out their round Jensen for some other alternative and how did it work for you? Thanks,
TimH
7 REPLIES 7
sleepy
Some pictures would be nice
some links would be better
We only watch ABC, CBS, NBC, Fox, and 3 PBS channels
In the camper we use the Lance mounted Weingard Satallite, crank up... it has the rtound dosk. It has to be oriented... it picks up electrical interference from vehicles with spark plugs that are "chipped" or just plain out of tune... sometimes the rolling boom-boxs
At home we have an antenna from WalMart ot Bestbuy... it is a ~ 14" x 8" x 1" rectangular antenna mounted on a length of conduit... we get 27 channels... it is directional
I would very much like to remove the disk on the camper antenna and ad a better antenna on the crank up sat antemma on the camper
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
iwon415
Thanks for the replies guys! They are helping me decide!
billyray50
kerry4951 wrote:
I replaced my Winegard bat wing with a Jack. Used the same mount so basicly you crank it up and down and can move it around. The Jack seems to work fine. I like the compactness of it on the roof compared to the old log bat wings. Dont need to use it a whole lot since we have sat TV most of the time.
X2 replaced old 1998 batwing on my Lance with Jack also. Works fine and like the smaller size too.
kerry4951
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
pa_traveler
Jensen was garbage,should be a crime to put them on an expensive new camper. We tried for months to figure out what was wrong,finally realized it need to go in the garbage can.Had dealer try jack antenna and sensar 1V on his lot in campers,the sensar with batwing worked best in that location,thats what we have now and it works well.That was a new 2011 if there still putting jensens on,cant understand it.
lap527
We changed ours out to batwing HD sensor IV, I think. Best decision for us. We went from 2 channels to 12. We thought about jack but decided against it after reading some of the reviews.
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer when needed.
camperpaul
Omnidirectional receive equally poorly in all directions.
The "Jack" is somewhat reasonable on the UHF channels but is marginal on the
VHF Hi channels and extremely poor on the VHF Lo channels.
Your best bet is to go with the Winegard Batwing.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
