As to camper weight, what does this sticker indicate?
RKW
Ryan
  • 2015 Ford F250
  • 2015 Rockwood Signature Ultralite 8280 WS
  • Dual Honda EU2000i Generators
    The wages of sin are death; but after they're done taking out taxes, it's just a tired feeling.
21 REPLIES 21
srschang
Most of a truck camper weight (often all the weight) will be on the rear axle. So you will be adding the loaded camper weight to the two rear tires and wheels. For that sticker the rear GAWR is 6100 lbs. On my truck, the rear axle weight (empty, without tailgate) is 3220 lbs. So if yours is similar, that leaves 2880 lbs for the truck camper, tie downs, cold water, hot water, propane, and stuff. I recently weighed my truck empty and fully loaded, and my "stuff" weighs about 800 lbs.
2022 Ram 3500 Dually Crewcab Longbed Cummins, 2019 Northstar 12 STC
sbryan
This sticker doesn't tell you anything about camper weight. You know what Ford says the GVWR and GAWR for the truck are but until you know the truck's weight you have no idea what the carrying capacity is. And on top of that you need to factor in your own risk tolerance since with a 10,000 pound GVWR many campers will put you over the GVWR. Get your truck to a scale with and without the load you plan to carry and then you'll have data with which to make decisions.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
sbryan
Shawn
Northstar Igloo 9.5
US Army retired
joerg68
Nomad III
Nomad III
... wrong edit ...
2014 Ford F350 XLT 6.2 SCLB + 2017 Northstar Arrow
joerg68
Nomad III
Nomad III
It tells you the GVWR and the axle weight ratings. You can weigh your truck at a scale, empty, and then you know how much payload is available.
There is another sticker that says "Tire and loading information" that tells you the (theoretical) payload ("the combined weight ... should never exceed ...").
RKW
markchengr wrote:
Can't see the image.
Hows about now?
Ryan
  • 2015 Ford F250
markchengr
