The last time I had pulled my travel trailer, I was shocked (pun intended) that with my truck running, and my 7-way trailer cable hooked to it, I was feeling a pulse of voltage when I touched the trailer door handle. I was literally escaping desert sand storm at that moment so I spent no time troubleshooting then and there. The truck was running and that was good enough for the moment. Fast forward to the current (again: pun intended), most if not all of the 7-way pins test like they are shorted to ground using my multimeter. I have three cables to the positive post of my trailer battery. One to the generator, one to the electric trailer jack, and one to the power distribution for the trailer. The positive cables to the power jack and the generator both are "open" when checking continuity between battery connector to ground. That is what I would expect. The cable from the battery to the trailer distribution reads about 350 ohms between the connector and ground. My suspicion is that this cable is grounding resulting in the shock that I felt and also showing the 7-way pins to be shorting to ground. I intend to trace the cable today best I can. I would love to know if anyone has experienced this sort of problem or any advice. Thanks in advance.
Cheers!
Dan
2005 Ford F-250 Fx4 Longbed
2007 26' FSAK Eclipse Attitude Toyhauler
