โFeb-10-2017 05:18 PM
โFeb-12-2017 02:09 PM
bjarnold wrote:
FIXED- I checked the part number on the circuit board on my Bounder and it matched the trailer. I swapped the board on the trailer and it fired right up
โFeb-12-2017 01:47 PM
bjarnold wrote:
For whatever reason he said he had the inverter installed and never used the gas function. I filled the LP tanks and fridge works fine on gas so I am going to leave it that way. The only reason I question the inverter is that is the only thing I unhooked after buying the trailer and wasn't sure afterwards if that could cause the water heater issue. I measured 12 volts with a voltmeter at the orange wire going into the control board. The brown wires have no power
โFeb-12-2017 12:10 PM
โFeb-11-2017 07:52 PM
โFeb-11-2017 07:42 PM
bjarnold wrote:
I had a local Atwood dealer check the board. The only tester they had was an old school Dinosaur board tester. The guy said it may or may not work with my style board. They hooked it up and got the gas valve and ignitor to operate on the tester. However it is still not working on the RV. It still works great and electric mode but not gas. I am still getting 12 volts to the orange wire going into the board but no power going to the gas valve or ECO switch
โFeb-11-2017 07:09 PM
bjarnold wrote:
The previous owner had an inverter installed so he could run the fridge on power instead of gas. I unplugged the inverter since I don't plan on any dry camping anytime soon. Could the 12 volts on the water heater be tied into that?
โFeb-11-2017 05:19 PM
โFeb-11-2017 03:30 PM
โFeb-11-2017 01:59 PM
โFeb-11-2017 01:55 AM
โFeb-10-2017 07:19 PM
bjarnold wrote:
It's a 2007 and the model is GC6AA-10E. I cleaned the terminals on the circuit board and I have 13 volts coming into the circuit board via the orange wire on the top plug
bjarnold wrote:
Atwood gas/electric water heater with DSI and it works fine on electric but does not work on gas. The gas valve does not open, the ignitor does not fire, the red light on the switch panel does not light up. I bypassed the thermostat and still doesn't work.
โFeb-10-2017 06:42 PM
โFeb-10-2017 06:36 PM
โFeb-10-2017 05:50 PM
