Dec-10-2017 09:38 AM
Dec-25-2017 11:09 AM
wowens79 wrote:
Well I found the problem, and figured I'd let y'all know in case it might help someone in the future.
There is a 2 amp fuse in a fuse holder at the bottom of the front awning leg. The wire on the fuse holder is pretty thick compare to the wire going to the lights, so I assumed it was for the motor on the awning. Turns out it is for the lights. The fuse in there the blades has some corrosion on them. I replace the fuse, and it works fine.
Thanks for the suggestion, it was a bad connection.
Dec-24-2017 07:05 PM
Dec-24-2017 06:56 PM
Dec-10-2017 06:13 PM
Dec-10-2017 02:53 PM
Dec-10-2017 10:54 AM
Dec-10-2017 10:05 AM
Dec-10-2017 09:54 AM
Amateur Radio K3EXU
