Back-up manual tongue jack
MargaretB
My husband is nervous about trailering because he's not mechanically inclined and fears trouble that he can't fix. So the issue of relying on the electric jack came up. I'm wondering if there is such a thing as a manual crank that can be used on a normally electric crank, just in case. Belt and suspenders, that's me. He's concerned about the battery running down and us not being able to hitch up or unhitch.
So is there such a thing as a manual crank for the jack?
Two retirees. Perpetual newbies. Techno- and mechanophobes.
2015 Tracer 230
2014 F-150 XLT EcoBoost
12 REPLIES 12
krobbe
I just carry a bottle jack and plenty of leveling blocks to tackle most emergency lifting jobs. Much more versatile than a manual tongue jack with a single purpose.
Me'62, DW'67, DS'04, DD'07
'03 Chevy Suburban 2500LT 4WD Vortec8.1L 4L85-E 3.73 CurtClassV
'09 BulletPremier295BHS 33'4" 7200#Loaded 1100#Tongue Equal-i-zerHitch Tires:Kumho857
Pics
Bull_Rider
It's important to keep the top of the electric jack covered when not in use. We use a small plastic bucket to keep the rain and snow out of the electric motor.
Fancy people will sew a bag our of marine vinyl or some other waterproof material. Either way will greatly extend the life of the unit.
If you receive help from other members, don't forget to update your topic with the results.
bguy
Last year my friends' 2014 Jayco had the electric jack fail. The servicing dealer was 250km away so he figured on using it manually until he got it there for the fall inspection. After a few weeks the jack jammed. Luckily it jammed low and he jacked it up with the tire jack to get it on the truck. Surprisingly enough the dealer made a house call ( which was now about 200 km away) and changed the jack under warranty. Pretty good of them because their official policy was for a 100 km radius.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
Gene_Ginny
Make sure you have some extra fuses and don't reverse the direction (up/down) until the motor stops turning.
Don't ask how I learned that one. :S
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Tom_Barb
jerem0621 wrote:
my best friend had a power tongue jack FAIL internally and collapsed the Tongue to the ground.
A simple bottle jack and a couple automotive jackstands helped get the tongue back up where it needed to be.
Thanks!
Jeremiah
Our's tthe motor smoked and that was all she wrote.
Bigbird65
My trailer came with a manual jack. I replaced it with an electric jack. I keep the manual jack in the back of my truck incase the electric jack fails. My bottle jack can hold the tougue up while I change the electric jack out. Only 3 bolts.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
MargaretB
Whew! Thanks, everyone - it's reassuring to know that we can crank it manually. And of course I never even thought about backing the Sequoia up and plugging in the 7-way. Duuuh.
Thanks again.
2015 Tracer 230
Huntindog
All electric jacks that I have seen can be operated manually.
When it comes to tongue jacks, there is something to consider. They come in two basic designs. A top mounted motor ie: Atwood or a side mounted motor ie; Barker, Ultrafab, Husky and the rest.
The top motor mount design is the same as a manual jack as far as that operation goes.
The side mounted jacks are different, and the difference can be a problem.
The emergency handle inserts into the roof of the housing, and is cranked on a horizontal plane. This can cause interference with the propane tanks, making the operation a real pain. You can only turn it half a revolution, then must remove the handle, turn it 180 degrees, reinsert it and repeat this many times. I found this out the hard way when a Ultrafab on my new TT failed when hitching it up for the first time at the dealers lot.... I only owned that jack for 20-30 minutes. The dealer agreed with me on the stupidity of the design, and gave me full credit towards an Atwood.
This may not be an issue for all TTs because of differing designs... But it for sure won't be an issue with the Atwood.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
jerem0621
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
nomad297
TucsonJim wrote:
All the electric jacks on the market that I've seen have a manual back up. Usually, you just use a socket and ratchet on the nut on top of the jack to perform this task. It's very easy and not complicated at all.
This^^^
And, if your battery goes dead, just back the truck up to the seven way and plug it in. Presto! You have 12 volts to your rongue jack.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
Jaxom
My electric jack has a little rubber plug on top. Remove the plug and use the included crank handle to raise or lower as needed.
Jerry
2015 Jayco Seneca 36FK
2011 Jeep Wrangler Sport 2 door
2011 R & R 20' Aluminum Enclosed Car Hauler
2007 Montrose 16' Aluminum Flatbed ATV Trailer
TucsonJim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
