Hi,
Depends on the capacity of the battery, charger, and how large the wire is between the charger and battery.
Lets say that you have #8 or better #6 wire between the battery and charger. #8 can carry 40 amps, #6 about 60 amps. You are good there.
A 45 amp charger came with my motorhome, you might have anything from 30 to 65 amps capacity, I have a 70 amp charger built into my inverter/charger.
Lets say that you pick out 28 pound group 24 battery with a 65 amp hour capacity. It will recharge in about 2 hours. But two of them will not keep the furnace running all night along with lights and other stuff.
Lets say that you pick up some 45 pound group 27 batteries with a 95 amp hour rating. You will get longer run time, and probably still have power in the morning after running the furnace all night. And be able to keep the RV around 65 on a 35F night. They should recharge in about 3-4 hours (for the pair) with a 45 amp charger.
What I would recommend is a pair of 67 pound golf cart batteries. Their capacity is 220 amp hours, and you need two of them to get a 12 volt battery bank. It will hold much more water than the pair of group 27 batteries, and if you get there on a Friday night, charge about a hour, then charge another 3-4 hours on Saturday, they will fully charge. An hour charging Sunday before leaving and it will fully charge again. Leave the battery disconnected on the days you will not be there, use a disconnect on the negative terminal.
Your RV has a basic load, about 24 amp hours per day. It will run the refrigerator, CO detector and propane leak detectors on that much power. If you leave the - terminal connected, it will discharge the battery in about 2-5 days. If you have a single 120 watt solar panel, in the summer it should keep the battery full, even if the propane and CO detectors are left on.
It is best to warm up the RV while the charger is on - if possible. This prevents you from needing to discharge the battery just after shutting off the generator.
Another way to warm the RV is a Olympic Catalytic Heater. You would leave a window and roof vent open about 1/2" and then run the 6,000 Btu heater on all the time - all night long. This will give you silent even heat all night, without any battery use at all. Did I mention it is quiet, will not wake you, and not use any 12 volt power?
I would still upgrade to the pair of golf cart batteries.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline waterEscapees.com
