Battery Draw down
mgann
Just replaced old with new group 31 rv battery. Nothing is switched on and LP monitor disconnected but something still drains my battery by 1 volt per day. Any help in resolving this is appreciated in advance.
2014 Chevrolet 1500, crew cab, srw, 2wd, 4.6 gas, Stock class V, 1995 Mallard by Fleetwood model 19n
17 REPLIES 17
GordonThree
Stick one of these in between the battery and your main positive cable. Suggest you leave the emergency breakaway switch direct to the battery.
https://www.westmarine.com/buy/blue-sea-systems--m-series-mini-single-circuit-on-off-battery-switch-...
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
midnightsadie
mines in the shop right now being traced .
enblethen
That is a good sized drain.
Start by locating your 12 volt DC power distribution panel. Remove each fuse watching closely for a small arc. Can also be scene where pushing fuse back in. The one with arc is the drain.
Next method is with ohm meter. Remove fuse, place one lead to ground and other on output terminal of fuse. With meter set on around 1000 scale look for resistance.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
