Battery question?
tuna_fisher
I was just looking at how I want to run my wiring for my future solar panels, went to my battery compartment and noticed the pos. post was very black in color, I just cleaned them a couple of weeks ago when filling them with water, what would cause them to turn black like that, it's never done that before. There's nothing hooked to the post as my wires are on the threaded post with a wing nut.
2001 GMC DM, 1995 Lance Lite, @005 Eclipse Toyhauler, Toy's!;)
14 REPLIES 14
gitpicker2009
actually, any basic spray paint can be used also. You just want to block oxygen from reaching the metals. I used to use vaseline like someone suggested, but it was too messy during later service. Clean the terminals/posts well, re connect, and then just spray paint. I paint one red and one black. Works like a charm.
ticki2
tuna fisher wrote:
ticki2 wrote:
Here is some interesting reading on the topic electrical connection compounds .
https://www.w8ji.com/dielectric_grease_vs_conductive_grease.htm
That was a lot of information on grease.How much of it I remember is questionable
Yeah , nothing is simple anymore . 🙂
'68 Avion C-11
'02 GMC DRW D/A flatbed
tuna_fisher
towpro
I like stuff that drys. I think the NO Ox and other electrical insulator greases stay wet and attract Dirt and anything else that touches it (like bugs, cloths, hands, etc)
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
ticki2
'68 Avion C-11
wyocowboy00
Anybody ever heard of "No Ox"? The old Western Electric installers used to use No Ox on every electrical connection they made.
2012 Chev. Silverado 3500HD DRW 4 X 4
2013 Arctic Fox 992 240 watts solar
Jerry & Judy
towpro
I have a can of Dykem blueing I use to coat the terminals.
so far the can has lasted 30 years, including using it to lap some vales over the years 🙂
2022 Ford F150
TxGearhead
Yes, stainless washers and stainless nylock nuts, no wingnuts.
I hear that grease is an insulator so don't put it on the post before the terminal. Use dielectric grease, or CRC battery terminal/post cleaner then CRC battery post protectant after connecting the terminal.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
theoldwizard1
hedge wrote:
IMO, I'd replace the wingnuts with actual nuts that you can put a wrench on and tighten as well.
Excellent tip ! Make then stainless steel nylocks for a buck or 2 more !!
HMS_Beagle
Flooded lead acid batteries routinely outgas corrosive gasses. That's why everything close to them turns black or green. Overcharging them makes them outgas A LOT. One of the major advantages of a good AGM is that the outgassing is far less (none, in the best of them).
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Lwiddis
Hedge, I agree. I want those nuts tighter than I can twist a wingnut.
hedge
2017 F350 Platinum DRW
2013 Adventurer 89RB
tuna_fisher
Ahhh, never experienced that before. Must be the rain we've got in the desert, haven't had any to speak of in the last 5 years. Wow, moisture in the air, how novel.
theoldwizard1
It is some reaction with oxygen in the air.
After cleaning, liberally coat the posts and cable clamps with grease. Vaseline works well.
