โMay-24-2017 04:26 PM
โJun-03-2017 03:48 PM
ticki2 wrote:cewillis wrote:NRALIFR wrote:
Easy fix for the fill hole: I suggest the use of a "Digitus Secundus Manus" (index finger) to check the oil level. The bung looks plenty big enough.
We think alike, friend.
Yep , a little common sense goes a long way . It does beg the question , since it is probably an axle specific cover , why the fill plugs isn't at the correct level to begin with . I am sure it is not a cheap cover .
โJun-01-2017 09:10 AM
GeoBoy wrote:
Mag-Hytec said no way, it can't be a 14 bolt cover, it was.
โMay-30-2017 06:06 PM
silversand wrote:CE Willis wrote:
The AAM 11.5 is used with all Duramax and 8.1L gas engines, and many Dodge trucks. (from 2003?? until current ASAIK)
....thanks for the clarification....I'd completely forgot about that monster 8.1 L gasser motor (with Allison) and big ring gear LOL
โMay-30-2017 07:38 AM
โMay-25-2017 01:09 PM
โMay-25-2017 12:55 PM
silversand wrote:
...nice job Cal! Those massive 10.5 and 11.5 GM Corporate (later, made by AAM) diffs are freaking awesome. I think that the Allison 1000 tranny with Duramax comes with the 11.5 inch rear end in the 3500?
The only thing with these big 14 bolters is: ....you know a GM Corp axle has been down the trail when you see plow furrows down the middle of the offroading trail LOL...
I think the only way to get that pumpkin higher off the trail is with very large diameter tires (and a change of ratio to ~4.56 with ~41-9 teeth...and fly-cut that big housing down an inch or more-ish).
The gear oil quantity is very well known for those diffs...after you put in the correct quantity, you bench-mark the level through the filler hole with a 90deg bent white wire tie..marked with indelible black marker..and throw that new tool in your glove box ๐
โMay-25-2017 12:53 PM
โMay-25-2017 12:08 PM
โMay-25-2017 10:23 AM
โMay-25-2017 07:41 AM
โMay-25-2017 07:38 AM
jefe 4x4 wrote:
Cal,
I suggest grinding off about 1/8 of an inch along the bottom of the cover so it's not the first thing to drag.
โMay-25-2017 07:35 AM
โMay-25-2017 07:32 AM
trail-explorer wrote:
It needs paint.
โMay-25-2017 07:29 AM
Home Skillet wrote:
That fill plug looks way too high up. You will be over filling the rear end,which will cause axle seal leaks.
Just my $0.02
