Best oxidation remover?
kennyd63
Good day to all -
What is the best oxidation remover for laminated fiberglass on T.T. out there with out breaking the bank and breaking my shoulder?
Thank you to all in advance :h
2019 Braxton Creek 24RLS
2010 Forest River Salem 403FB-Destination Trailer
2014 F150 4X4 Crew Cab
20 REPLIES 20
kennyd63
Chuck_thehammer wrote:
acetone... go slow and NOT ON PAINT. and be careful around plastic.
did my Coachmen Cascade last year. about 2 gallons... lots of old T shirts. then wax.
Walmart paint department. and YES elbow grease.. and more elbow grease.
and my trailer is a 2005 and never cleaned or washed.. not bad but looked weathered. and LOTS of black streaks from bent gutters..
and the Cascade is WHITE....
used a power buffer for the wax... wax on... wax off... Looks real good now.
Thank you Chuck!!:B
kennyd63
rockhillmanor wrote:
kennyd63 wrote:
gbopp wrote:
Bar Keepers Friend.
Never heard of it..
Bar keepers friend is liken to Comet. Its a kitchen cleaner and was used on bars in restaurants and on the brass fittings of the beer tapper etc. Henceforth the name.
It should NOT be used on vehicles. It WILL scratch the finish.
Thank's gboop ๐Ÿ™‚
kennyd63
Ava wrote:
Rubbing on Vaseline works as well. I have done a badly oxidized boat with it and worked great. Less offensive than trans oil.
I like this. I will give this a try.:)
Ava
rockhillmanor
kennyd63 wrote:
gbopp wrote:
Bar Keepers Friend.
Never heard of it..
kennyd63
Dennis12 wrote:
Try using transmission fluid. You will have to do it every 3 to 4 months. Nothing will stick to it. Easiest way i can tell you.
are you for real Dennis12? I mean that.
kennyd63
kennyd63
Mark Heisler wrote:
Mequires Ultimate Compound and then nufinsh polish
Or you can use this stuff too I have done both
wash your trailer with awesome(this will make it easier to deoxidation)
meguiars power cut compound #M91(for deoxidation)(orange pad)
nu-finsh(white pad)after the first app I put a second one on 2-3 week after
I use a portal cable DA polisher with lake country pads
my trailer will shine for about a year
This sound good..
kennyd63
gbopp wrote:
Bar Keepers Friend.
Never heard of it..
kennyd63
gbopp wrote:
Bar Keepers Friend.
Never heard of it..
kennyd63
WNYBob wrote:
Try using your elbow, as in elbow grease.
I already tried that!! did not work.:B
westend
I use Jasco Prepaint Conditioner at 50% dilution in a tank sprayer. Clean surface, apply Jasco, lightly swirl it with a brush on handle, reapply Jasco, and rinse.
This solution will work on painted surfaces, also.
'03 F-250 4x4 CC
rockhillmanor
I just use McGuires 'cleaner' wax. Been using it for years on my RV.
ONE step, put on, rub off, and watch it shine.
See the top? That's the oxidized part I couldn't reach without dragging my ladder out. Below is the shine from one application of wax.
It's not rocket science and IMHO I would NOT use any of those ruby reds clear coat treatments or whatever they call it treatments on your RV. There have been 'numerous' reports of what happens when they start to wear off in patches and all what you have to do to get the darn stuff off.
Did the top part at the next CG stop when I felt more like taking the ladder down off the back of the MH. :W
sbowman871
I just got this in but have not tried it yet. This was recommended by my RV manufacturer.
http://www.detailing.com/store/3m-marine-restorer-and-wax-32-oz.html?gdffi=acdb1f1dcc25482d9ccd35b60adf4af6&gdfms=F75D83819B764FBFB4647305AB191FE2
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
Parkit 360
