Nov-21-2013 04:53 PM
Dec-11-2013 09:24 AM
spike99 wrote:
I still don't understand why some folks don't like Spray Foam (CC - contractor grade) under their RV/TT. I applied under my RV/TT and its amazing stuff. And, it isn't too much work to install.
After seeing benefits of before and after with my own eyes, IM RV/TTs should use Foam (spray or vacuum bonded) as minimum factory build.
Dec-11-2013 07:47 AM
Dec-10-2013 10:21 PM
Nov-23-2013 08:32 AM
Nov-23-2013 03:53 AM
Nov-22-2013 10:54 PM
Nov-22-2013 07:54 AM
Nov-22-2013 05:58 AM
westend wrote:
Could you guys that have improved the under-belly sections of your TT's comment on the results and maybe some changes you would/should have made?
Thanks for posting the different projects. It's a credit to you guys that have taken the time to take pictures to share.
Nov-22-2013 05:03 AM
Nov-21-2013 10:34 PM
TECMike wrote:
Been trying to wrap my mind about how to go about insulating the bottom of our three season trailer. Our little Sunnybrook Harmony has exposed tanks and I am in the process of installing tank heaters. However I would like to add a little insulation to the bottom, which has a black composite material covering the bottom of the floor.
I have asked this question before, but am having a problem understanding how to choose a product that will not cause a problem with moisture to the existing floor structure.
Also I have eliminated spray foam as a choice as I can see it being a problem if I ever need to gain access to the underside flooring.
So is there a product that both breathes and provides insulation at the same time that might fit my application? Thanks in advance. Mike
Nov-21-2013 10:13 PM
Nov-21-2013 09:31 PM
Nov-21-2013 07:25 PM
Nov-21-2013 06:25 PM
