Jul-03-2013 06:31 PM
Jul-04-2013 04:24 AM
HappyKayakers wrote:
Yes, it's very straight forward. Take the old one off first and measure so you get the same length replacement. I saw someone selling 72" replacement cables on eBay for $20, so $50 sounds a little high.
Jul-04-2013 04:22 AM
camperforlife wrote:
When you cut the underbelly cut a three sided flap especially if it is coroplast. When closing up the belly, you can punch a couple holes at the loose end of the coroplast and secure it shut with zip ties before you seal the seams with Gorilla tape.
Get the shortest cable as possible to suit your needs. If the cable is too long make a wide arc so it won't kink and anchor it in twice as many places as you think is needed. You will see that the manufacturer just hooked up the cable, kind of anchored it and closed things up.
Good luck!
Jul-03-2013 11:48 PM
Jul-03-2013 08:03 PM
Jul-03-2013 06:38 PM
