Blank Tank Flush Leaking At The Tank (need some help)
Aluminum_Siding
Yesterday after our week vacation I was flushing the black tank when I noticed it dripping from the under belly. It was clear so I started at the easiest visible connections. I cut the underbelly back a bit and it was leaking only when the hose is on. It's leaking at the center of the flange where the plastic goes into the tank in the center of the flange. This part swivels and I'm not sure if its suppose to. Its only dripping and not too bad. Is it suppose to swivel, does it tighten from the inside? Can I disconnect the hose and twist it around to tighten?
I cannot find an OEM replacement so my second question is if I use an aftermarket universal one, how would I patch any screw holes that did not align etc. What type of silicone is best for these tanks. The stuff on there now is clear. I'm also worried if I don't replace it black water may seep out. Not sure if there is a anti back flow at the actual flush.
Thanks for the suggestions. Mike
1 REPLY 1
mooky_stinks
As long as you have access to it right now I would disconnect and remove the flusher to check and see whats wrong. It should only be 3 small screws to remove. That way you can clean the sprayer because they are known for clogging. A lot of people drill the holes in the sprayer a little larger to avoid clogging. Mine clogged this spring and it was only a 15 minute job to remove and reinstall. I just used a generous amount of GE Supreme silicone when I put it back in. I don't remember being able to swivel the fitting. That could very well be why it's leaking.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
