Brake lights very dim
germanic333
Not sure if anyone has had a situation like this, but my brake lights are dim, I am getting a reading of 2 volts DC, I am guessing I should have 12 volts DC, any suggestions on where to start would be appreciated. Ken
3 REPLIES 3
Mark_Heisler
poor ground (broken or dirty)
clean the ground at the lights
make sure you have a good ground wire on you trailer and tow vehicle(do not ground through the ball. Have ground wires through the plugs)
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
bdpreece
Totally agree with RinCountry you most likely have a grounding problem. Try running a separate dedicated ground wire from the tow vehicle to the trailer.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
RimCountry
I'm not an electrician, but I'd go for the simplest first and check my ground... depending on what type of unit it is, you might be able to get by with just unscrewing the ground wire in the lamp fixture, dosing it with WD-40 and re-assembling it. I'd do the same up at the connector - the WD-40 part. Good luck.
Michael, Suzy & Arnie Asada (Chihuahua)
'97 Viking Legend 2480
'19 RAM 1500 Laramie 5.7L Hemi
