Brake Pads
maxwell11
I have a 2005 Dodge Diesel 2500 Quad cab short bed, 80K miles
I purchased new brake pads:
Wagner Thermo Quiet
Made by Federal Mogul
Have any of you guys used these brake pads,
If so, how did they perform?????
Cost about $95 out the door with tax.
36 REPLIES 36
K_Charles
I too wonder how fast you need to drive to turn 9 years into 14.
My 2005 is no where near 14 years old.
path1
Wagner Thermo Quiet
Out of curiosity, What point are you supposed replace pads?
I think I'm getting down there but not sure when to replace.
Any surprises putting them on?
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
thomasmnile
maxwell11 wrote:
do any of you change out the brake fluid? truck is 14 years old!!!!
Yes I do. My mechanic has performed a complete purge/refill of the brakes system. He tells me this service performed occasionally is cheaper than replacing an ABS module. And I agree.........
Water-Bug
How is a 2005 14 years old? Did I miss 5 years somewhere? I know that I 'm getting up there in age but didn't think that Alzheimers had set in just yet.
maxwell11
JustLabs wrote:
fj12ryder wrote:
That's a good price for all 4 wheels, kinda high for just the fronts.
I was thinking its a high price for pads,even for all four corners.
I've use the Thermo Quiets. Decent pad,middle of the road.
IIRC I saw a $30 rebate on Wagner pads while at the parts store the other day. You may want to check it out.
it was for all four corners
may be a little high but I wanted a good set of pads,
in the pass I have had the long last super hard pads, but they made noise, I did not want that.
when pulling that travel trailer, I just wanted brakes in good shape.
just thought it best to ask before I had them installed.
JustLabs
2011 Chevrolet 2500HD LTZ 4x4 CCLB Duramax/Allison
2007 Keystone Cougar 289BHS Fifth Wheel.
fj12ryder
I've used them on my Dodge 1 ton quad cab dually fronts, and they seem to work okay. I usually can't tell the difference from one kind of pad to another to tell the truth. Unless the one is really bad.
Howard and Peggy
"Don't Panic"
