Brakes AGAIN !
groundhogy
Hi,
So I am again smelling burnt brake smell on my 2003 7.3L F-250.
In the last few years, every one of those brakes has been replaced.
Rebuilt calipers, hoses, and pads.
Now Im smelling the back starboard side rear again. The wheel is warm to the touch after driving. This will be the third time for this unit in the last 3-4 years.
Any ideas on why this is happening or what I might be doing wrong?
groundhogy
37 REPLIES 37
mapguy
groundhogy wrote:
So, I had a phone conversation with an engineer at Centric.
He focused on two things.
First was the rubber seal that seals the piston and piston bore (cylinder). He said with new calipers, the surface where the seal goes is almost mirror finish. On remanufuactured units, the surface gets sand blasted. So with the sandblasted surface that the rubber seal sits against, moisture/rust can creep in there easily. So in many returned cores, he sees alot of corrosion in that area causing sticking pistons.
His recommendation? When you receive the new remanufactured caliper, get a syringe and squirt a bunch of dielectric grease (superlube for example) under the seal and into that area. He also said you might even just take some silicone caulk and put that over the outside of the seal(although he hasnt tried this, but it just popped into his head at the moment). Doing this will help prevent moisture entry.
He also said that they offer a zinc plated and painted caliper. He says some of the plating goes into the bore a little bit. So if you order the plated version from Centric, this also will resist the rust effect.
The second observation.
He says that when you get uneven pad wear, one piston is out further than the other. But, both the back of the pad and the head of each piston is flat. So smashing these together makes the phenolic piston crook inside the bore. So when the piston crooks or cants or twists sideways inside the bore, it gets bite marks on it, material might get scraped off of the piston. Bad things.
I did confirm with him that they replace all pistons with new.
I still am in search of the Centric warranty on these units if anyone knows.
IMO - be careful with the information given by this person.
groundhogy
Another thought of mine...
So, say you have a 2003 F-250. Its getting older.
Say the brake caliper design is prone to sticking and gets replaced alot.
So now imagine you are the caliper. Say you were born in 2003. How many times have you cycled onto a truck and into a reman factory?
How manytimes has your little mirror finish surface been sand blasted?
How flat or how wavy is that surface now? lol.
And is there any other surfaces on the caliper that will degrade with many sand blastings?
groundhogy
TakingThe5th
whjco wrote:
Have you checked the parking brake for a sticking cable?
I'm not the OP, but I've checked the parking brake on my truck and it's OK, but this has also happened with the front calipers. I've also had this problem since the truck was new and all of those calipers have seized and been replaced so I haven't seen where it is a remanufacturing problem. But it does make me wonder if there was a supplier who made a bad caliper since some have the problem and some people don't.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
whjco
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
whjco
groundhogy
I had a 94 ford explorer and got 320k miles on it.
Best vehicle I ever owned. Dont remember ever changing calipers! Lol
I am wondering if its not a ford problem but a remanufacturer problem?
Grit_dog
Navigator
Navigator
I never saw or realized the Super duty brake caliper issues. Granted, the trucks I/ the company had were all 5yrs old or newer, but Had a contractor working for us that was running a huge fleet of old 6.0s that were 10 years old, in the Arctic and didn't see those issues. No road salt up there though. We wanted the roads to freeze! Lol
Grit_dog
Navigator
Navigator
72cougarxr7 wrote:
I concur that the phenolic caliper pistons seem to be the cause of the Superduty sticking brake issue. I replaced all 4 calipers on my 2008 f350 last year, 1 piston in the rear and 1 on the front would stick and drag the brakes.
I had the same issue on a ranger I drove in high school.
On the rear of my F350, I was able to order new (not reman/rebuilt) Raybestos calipers from rock auto. They honestly looked better than oem quality.
I also siphoned the old fluid out of the master cylinder, put in fresh fluid, and let each caliper gravity bleed until fresh fluid came out. I plan on flushing the fluid once a year to keep fresh fluid in the system. Brake fluid absorbs moisture, which naturally settles to the bottom of the system, which is the calipers.
I believe you're right. But no need to do brake fluid every year. Most people don't do it ever. Fwiw, I do a "slow" brake fluid exchange. Every year or 2 I suck the mater cyl dry on stuff and refill a couple times. Uses more brake fluid but it works!
groundhogy
Ok, I have been reading other forums the last couple of nights...
I am reading that some of the caliper remanufacturers will reuse the pistons if they look ok to save money.
I have also read that the majority of binding incidents occur with the pistons getting stuck more than the guide pins.
There is also a good engineering reason that they use phenolic. I just cant remember it. lol. Temperature insulation? Or corrosion of the wet brake fluid?
Also read one guy where I guess he ended up with two mismatched pieces and the guide pin holes on both parts were 0.030" off. So no slidy good.
Anyway, I have searched and found two companies that DO replace the pistons with new units.
Centric and NuGeon
I went to the Motorcraft site and they probably do, but I cant tell for sure by the verbiage.
I am searching local sources, but they are both available on Rock Ahuto.
Im planing Centric. Have an email out asking about their warranty.
72cougarxr7
groundhogy
On the Port/Starboard thing. Once you get used to it, it becomes the simplest, easiest, least confusing way to communicate where things are on any craft.
Plus i can pretend I’m still on my boat....
TakingThe5th
Grit dog wrote:
And if a person, especially living in the salt belt, does not adequate lube the slides, that is the second most likely cause IMO.
No "light grease rubs" into the pores of the steel. First, it sounds dirty or you're having too much fun rubbing your pins...
Anti seize that stuff and be done with it.
Glad you enjoyed my "grease rub" comment. What I meant to say
was I used the smallest amount of "grease" to moisten the metal without the danger of getting it on the pads or rotor. To do that I have used my bottle of brake caliper lube, or those little packets that they sometimes throw in, or anti-seize - I've tried them all.
I've considered the salt issue. I clean my brakes every year, only because of this problem, and I see no salt-related issues. I've heard some people talk about concern over the "beet juice" that they spread on the roads here - some say it is more corrosive then salt but, again, I'm not seeing it in my brakes and my truck is still almost rust-free. And my other vehicles are having no problems like this.
I too have been exercising the ABS system as well as I can to purge out old fluid but I've also heard that having a computer program that can open the valves in the ABS would be a nice way to flush it out completely, But since I have been having this problem since the truck was nearly new I wonder if the ABS unit has been defective rather then worn out or old but haven't found anything on the internet that would support that thought.
If you are wondering why I didn't take the truck in under warranty for the ABS unit - this problem wasn't that obvious until after the warranty expired. I hadn't put many miles on it and I thought the problems were related to lack of use.
Procrastinator
groundhogy wrote:
Hi,
groundhogy
Sorry, I just wanted to post up praise for your description "starboard" side rear.
I did a couple of enlistments in the Navy both on a ship and later on land in the Seabees. In the middle of the country, you don't hear people use port and starboard often.
2018 F150 Max Tow with 6.5 "long" bed.
2019 Coachman Freedom Express Liberty 292BHDSLE
