โNov-11-2013 06:10 AM
โFeb-24-2014 06:31 PM
โFeb-24-2014 06:16 PM
Oigetit2 wrote:
I've got a 99 Minnie Winnie, and am trying to find a CB antenna that will work I can't put one on the roof due to height, so thought the mirror, but can't find a bracket that will work. Any suggestions?? Thanks-
โFeb-24-2014 06:14 PM
Oigetit2 wrote:
I've got a 99 Minnie Winnie --- snip ---
โFeb-24-2014 06:03 PM
โNov-27-2013 05:21 PM
Wes Tausend wrote:I'm not sure how good the Cobra 148GTL's are these days, but back in the day, they were truly great radios, at a very affordable price. With a little minor tuning, they had great modulation and it was easy to set them up with 'funny' channels too. Their recieve was quieter than many radios, but still sensitive to hear weak signals. They had pretty good 'garbage rejection'.SoCalDesertRider wrote:SoCal,
I wouldn't fool around with that clamp-on doo-hickey. Just drill the hole and be done with it. You can plug it with a plastic plug or rubber grommet when you're ready to sell the truck.
102" whips, when used with the stud mount and heavy duty spring, which makes them 108-109" long, exactly the 1/4 wave length of the 11 meter band, and mounted anywhere they can get a descent ground plane, usually give a nice wide, flat bandwidth for operating safely on many channels above and below the 40 channel CB band, even with an amp. The recieve and transmit signal strength of the 102 is usually also excellent, if the radio is at all descent.
A well-mounted 102 and a good mic can turn a cheap-o mud duck radio into an acceptable communicator, and turn a good radio into a real talkin' machine. ๐
I'll keep in mind that the wrap-around chain clamp may not work as well as it did before. It probably mounted better than you are imagining on the old solid bumper, since it nearly embedded itself in the metal and would not move even if kicked with a foot. As of now I am reluctant to mount it purposely looser to protect the clear-coat and have it probably move around besides.
I do need a higher quality radio and should probably measure signal strength in a radius around the truck. My hope is that advances in tech will provide a cleaner, quieter monitor. SSB would be a bonus in this department, from what it sounds.
Thanks again.
Wes
โNov-27-2013 12:29 PM
โNov-26-2013 08:01 AM
โNov-25-2013 10:02 AM
Wes Tausend wrote:I wouldn't fool around with that clamp-on doo-hickey. Just drill the hole and be done with it. You can plug it with a plastic plug or rubber grommet when you're ready to sell the truck.SoCalDesertRider wrote:
Should work fine if you use a star washer inside the bumper on the antenna's stud mount, assuming you're mounting it through a hole you will drill in the upper surface of the bumper. Doesn't really matter what the outter surface of the bumper is coated with, since the plastic insulator of the stud mount will keep the antenna from touching the top surface of the bumper anyways. It's the bottom (inside) surface of the bumper where the coax's ground connection is made, via the stud mount.
SoCal, Don,
Thanks for the replies. I should have mentioned, I formally used a chain clamp for mounting to avoid holes in the bumper. Normally this link-mount was grounded directly on the underside, but in this case the clearcoat will likely insulate this from happening and I probably should protect the more fragile finish further with a bit of nylon strap.
Maybe I can form a hidden electrical ground contact surface directly on the nearby backside of the bumper. I do have a SWR meter, but it seems the ratio had never been too low with any mobile antenna mount I've tried anyway. Hope it's not too much worse.
Wes
โNov-25-2013 09:56 AM
Perrysburg Dodgeboy wrote:Good point.
I would think an extra ground strap would be a good idea. The better the the ground the quieter your radio I have found.
Don
โNov-25-2013 07:57 AM
โNov-25-2013 05:36 AM
โNov-24-2013 09:33 PM
โNov-24-2013 07:13 PM
โNov-23-2013 04:41 AM
Perrysburg Dodgeboy wrote:I had ok SWR and bandwidth mounting the 102's on the rear half of the bedrails of my trucks. The bandwidth really improved when I mounted one on the rear edge of the roof, over the interior light. I've had them mounted on the center section of gull-wing cross-bed tool boxes with ok results.SoCalDesertRider wrote:
Been a few times lately on the interstate it would have been nice to find out what the traffic jams were about. Cant get that info on my fancy smart phone with internet, GPS, etc. Good 'ol CB radio is best. Always some truckers on it that are in the know.
Yep the 102' whip is the best antenna for CB use and coolest looking antenna. However it is very impractical to mount. The best location for any antenna smaller then 102" is in/on the center of the roof.
BTW not sure what kind of GPS system you are running the factory system in my wife's 200 will give you the option to reroute you around any traffic jams. That is only if the reroute will save your any time.
Don
