Charging the truck battery with solar- will a 1.5W panel do?
Sentinelist
Correction: I have two batteries (recent DuraLast Gold FLAs), and two 1.5W solar panels connected to each respectively with battery clips. They're just not doing the task, and I have them on my dash in heavy sunlight during the afternoon for at least 4 hours, west facing. They're velcro'd to the dash, not suction cupped to the windshield (about to do that). Did I buy the wrong panels? Do I need more power? The batteries are draining - even without the camper plugged into the truck now! - after just a few days. Maybe I have battery problems, though they tested good at AutoZone late last year. A trickle charge battery tender on a long extension cord resolves the trouble and then the batteries have no trouble cranking. Thoughts?
'The TerraShuttle'
1993 Chevrolet Silverado K3500 6.5L mechanically-injected turbo-diesel 4x4 quad-cab SRW long-bed, Olympic White, 278k miles, 2001 Lance 815 self-contained TC rig
My build thread
20 REPLIES 20
narcodog
I can relate to the computers drawing down your battery's. When I bought my 03 Chevy I would not drive it for weeks at a time. When I would go to drive it the battery was dead. I took it to the dealer they did all sorts of tests and everything was fine. They put a big battery in it still did not fox the problem.
After I retired and I drive the truck more often, well no more dead battery problems.
tempforce
if your vehicle has a computer in it. the computer will draw down the batteries in a few weeks. if the draw is large say batteries drain in less than two weeks something is wrong..
i agree, you need larger solar panels to keep the system charged.
i use a little fence/gate solar panel on my old ranger... it has -0- electronic loads..
somewhere in the texas 'lost pines'
currently without rv.
'13' Ford Fusion
'83' Ford Ranger with a 2.2 Diesel.
'56' Ford F100, 4.6 32 valve v8, crown vic front suspension.
downsizing from a 1 ton diesel and a 32' trailer, to a 19-21' trailer for the '56'.
Sentinelist
Thanks, all. It sounds like I have a parasitic draw- I just chased one of these down in another of my vehicles last month so I'm well versed! I'll start there. After I take these puny panels back to Harbor Freight... I'm now looking at a couple good 10W panels rated highly on Amazon that I can replace them with on my dash with a charge controller each. Of note, the batteries are actually already running in parallel. I'm assuming with a charge controller on each, it won't be an issue interfering with that.
The goal is to be able to walk out after 3 months (or something) and have the trunk crank right up.
Separately, I'm about to setup 200W of solar on top of the camper with a 30A controller and a separate battery bank (see earlier thread today regarding my Lance for install spaces). I'm hoping to use a battery isolator to tie these two together better than the camper's 7-way plug that currently connects it to the truck with a single marine battery and just drains the snot out of my truck batteries. Solving problems by complicating them!
'The TerraShuttle'
My build thread
hmknightnc
If they are draining to where they won't crank the truck after a few days without the TC plugged in the batteries are failing or you have a pretty significant parasitic draw (short somewhere). The batteries just sitting in truck should last several months. Start chasing down that short
To answer your question directly - for large batteries use 10watts per battery if not using a controller.
time2roll
I recommend 5 watts to 10 watts per battery. If you have parasitic loads then aim for the high end.
Better to get 40 to 100 watts and a small controller.
Mandalay_Parr
Probably way too small. 12 watts would equal about 1amp with no losses.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
