Can anyone elaborate on what the normal tire pressure should be gor a Cherokee 26bh TT? The manual says 50 psi but the tires say 50 psi MAX....for each of the four tires...
Depends what tires you're using, but generally 50 psi is great!
2014 F-250 2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!) 2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In) 2018 Lance 1685 w/ Solar & 4 Seasons Package 1999 Beneteau 461 Oceanis Yacht En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
Most people air to the max as indicated on the sidewall. Some tire manufacturers have an air pressure vs loaded weight chart on their web sites. But you must weigh the trailer and know the actual weight on the tires before you can adjust the pressure according to their charts.
