Condensation issues in pop up
tapplegate
Good evening everyone,
How can you reduce condensation inside a Pop up. We have used Damp rid... Did not work... Not sure what to do? Advice appreciated. Will have another question tomorrow... To upgrade to a hard side pop up or not??
8 REPLIES 8
GypsyJeepWoman
I don't know if this would help with the popup, because I haven't had one, but maybe there is a parallel. Some tent bags don't keep the moisture out well when they are stored. So we put them inside of another plastic bag. If moisture is an issue in your geographic area when your popup is parked, would it help to put an extra cover over it?
I'd like nothing better than to achieve some bold adventure, worthy of our trip. --Aristophanes
Less_Stuff
This might work in a folded trailer.
Golden Rod Dehumidifier
DG
Former user name: "Lots of Stuff"
2015 RAM 1500 V6 8 speed
Regular cab short bed 2 wheel drive.
Leer 180 Topper
p220sigman
You may have something else going on that is allowing moisture in when it is closed up. I don't know if you are in the Crawfordville in my neck of the woods, but we have never had a problem with condensation in our Pup while it was closed and it is stored outside. The interior temperature is about the same as the exterior temp during the overnight/early morning times when condensation usually forms on other stuff around here.
tapplegate
Thanks everyone for the suggestions will used them when we camp, BUT, but I forget to explain that it is only when we open up the pop up. do we see a lot of moisture on the ceiling by the door and slide out as well as on the plastic canvas? We are wondering since we store it outside, that most likely the different temperatures are causing havoc inside. Any suggestions while it is stored to help with this issue?
Terryallan
Zip open both sides bunk end a few inches at the top where it meets the hard top. that will allow ventilation, and allow the moisture from you bodies, and breath to escape. Believe it or not. Most of the moisture is coming from you. Let it out.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
pianotuna
Nomad III
Nomad III
Hi,
Open a roof vent, and open a window as far from the vent as possible. Vary the size of the openings until condensation stops.
Regards, Don
RoyB
I have had great success with the O2COOL 10-inch AC/DC/D-CELL portable fan (Walmart-Lowes-AMazon)... I actually have two of these and use on both bed ends... This fan works great in all of our camping modes since it works from multiple power sources. This fan is very quiet in operation and produces a good air flow being a 10-inch blade model.
If I run my oil-filled electric heaters from the 20AMP service at the camp grounds using additional extensions cords in lieu of the propane furnace I reduce the condensation big time. I guess alot of moisture comes out of the propane furnace heater... It is always neat for us to use their power instead of our propane as well.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
newman_fulltime
You need to have air circulation get a fan .try cracking the vent open
