Converter/charger ?
Goyo
Hi folks, I am new to this forum and have just bought a 2007 Okanagan 811SL camper. I am looking for the converter/charger. Any help would be greatly appreciated!
6 REPLIES 6
RoyB
My camper has the WFCO WF8900 Distribution Panel with the Circuit Breakers and Fuses... The Converter/Charger unit is installed in the bottom compartment of this panel...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
cavie
Kayteg1 wrote:
Don't you have factory unit in the camper already?
Would I need new converter, I would consider inverter/charger instead.
Probably more educated advise in Tech Section.
OP is looking for the one he has not a new one.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
gbopp
Because you're trying to find the location of the converter, I think you will get the best advice in the TC forum.
opnspaces
Navigator
Navigator
Look for a brown or black panel that seems to have no purpose. Figure out out how to open that panel and you will probably find the fuses and breakers. The converter charger is typically part of the whole fuse\breaker unit.
time2roll
Look in or near or behind the panel that has the stack of circuit breakers and fuses.
Kayteg1
