Custom PIDs for 2004 Ford 6.8L V10 (2-valve)
BigMac
I've recently downloaded the Torque Pro app for my Android phone to use in my MH. Engine is a 2004 Ford 6.8L V10 (2-valve). Because of the MH size and also towing a car, long or steep hills can be a challenge, so I'm trying to fine a Custom PID to monitor transmission fluid temp in Torque Pro. I've read that the Custom PIDs for trans temp that are provided with the app are for the 6.0L diesel. Can anyone provide or direct me to a source for a transmission fluid temp Custom PID for my motor? Thanks.
Mike and Cindy
FMCA / Good Sam Member
2016 Tiffin Allegro Open Road 34 PA
2010 Pontiac G6
11 REPLIES 11
Bruce_H_
It is most reassuring to hear that Torque Pro with ScanTool OBDLink LX will read transmission fluid temperature. Just yesterday I ordered the ScanTool OBDLink MX for the purpose of reading TFT, and I've been sitting here wondering if I had made a mistake. Now relieved.
Bruce
2012 Lance 1575 TT pulled by 2013 4WD Expedition with HD Tow Package
BigMac
OK. Time to move on then. Thanks
Mike and Cindy
2010 Pontiac G6
dodge_guy
I don't think the pcm even reads engine oil temp? Don't think there is even a sensor?
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Desert_Captain
I was told by the folks at Scan Gauge that engine oil temp is not available on the 6.8 V-10.
BigMac
Received the ODB transmitter (ScanTool OBD Link XL) and installed it this morning. Connection to the ECU went well and Torque connected after I figured out what I was doing. Turns out that the Trans. Fluid Temp gauges did work and were active right from the start (both calc methods). What I can't get is Engine Oil Temp. Neither Custom PID is working. I've been trying to find a thread regarding EOT on the 6.8L V10, but haven't found one with a resolution to no EOT. Any info out there? Thanks.
Mike and Cindy
2010 Pontiac G6
Desert_Captain
Hank85713 wrote:
check out a scan gauge, dont know what they have for your rig but they should have something. Available at autozone, camp world etc about $150. It is not a tuner, just a gauge, plugs into obd port under steering wheel
X2 I always run my Scan Gauge with the trans fluid temp and coolant temps displayed (along with average and real time mpg). You can buy it on Amazon for $139, occasionally less. I ran it on my 5.4L F-150 and simply reprogrammed it for the 6.8L V-10 when we bought our Class C. Hands down the best $139 I ever spent on a vehicle.
:C
BigMac
Thanks everyone. I got a little spooked about the disclaimer saying you could screw up your system if you use incorrect PIDs. I guess that is more for custom PIDs not provided with the app. Anyway, the bluetooth adapter arrives today, so I'm going to set up some gauges and see how it all works.
Thanks
Mike and Cindy
2010 Pontiac G6
dodge_guy
Yep I`m running the Dash Command. Just used it yesterday coming to NC. it worked great! it`s nice knowing the actual numbers instead of a gauge with "H" and "L". The App is $10 and then another $10 for the 2002 Ford PIDS. Not sure with the Torque App, but there are different types of PIDS for each reading for the Dash Command, so like TUCQUALA said you may have to try a couple different PIDS.
Wife Kim
Son Brandon 17yrs
Dog Bailey
TUCQUALA
I use Torque Pro on a 2003 V10 Excursion, and the Ford PID's that are located in the software work just fine. Transmission temp is there and accurate. You may see 2 different trans temp PID's, just try one or the other and if nothing registers, use the other. It doesn't seem to matter if it's gas or diesel. Obviously some won't work with your rig!!
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
jerem0621
Download dash command.
It's a $10 or $20 app and you can buy the ford PID for $10.00 that can read the transmission temp.
User DodgeGuy has a V10 and uses this app. I use it as well on my 2000 lincoln.
Thanks,
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
Hank85713
