Feb-01-2019 06:32 AM
Feb-02-2019 05:08 AM
Cobra21 wrote:This is my belief as well. For short hauls I probably wouldn't spend the money. For cross country trips it makes it a more pleasant experience. I use a Reese Dual Cam on the TT's.
Whether you need one or not, they make A lot of Positive handling and riding improvements. I wouldn't go on a long haul without!
Brian
Feb-02-2019 03:51 AM
discovery4us wrote:
A Ram 2500 Diesel will have no problem towing an 8,000 lbs. trailer without a WDH. Outside the RV industry people pull much heavier than that. Make sure the drawbar is rated for the trailer weight and you will be good to go.
Feb-01-2019 11:18 PM
Feb-01-2019 02:11 PM
Feb-01-2019 01:06 PM
Feb-01-2019 12:41 PM
Feb-01-2019 12:32 PM
Feb-01-2019 12:18 PM
Feb-01-2019 12:16 PM
mjbenedict wrote:IdaD wrote:
The hitch rating is 1800 lbs, so tongue weight isn't an issue. I wouldn't be too worried about giving it a shot on a ball. Might find you don'd need a WDH and certainly front axle unloading isn't going to be a concern with that CTD sitting up front.
That's most likely 1800lbs with a weight distribution setup. You're probably ok because most hitches are about half that without the weight distribution. That would be around 900lbs hitch weight. My 7500lb trailer fully loaded is 1000lbs hitch weight and can reach 1100lbs so it would be best to keep your trailer empty without the weight distribution.
Feb-01-2019 12:02 PM
Feb-01-2019 11:27 AM
Feb-01-2019 11:10 AM
ScottG wrote:
Yesterday I saw a HD diesel truck pulling an empty constriction trailer on the freeway. It was no where near his capacity bot it was all over the road.
Feb-01-2019 10:55 AM
Feb-01-2019 10:17 AM
Feb-01-2019 09:23 AM
