Dodge 1500 Diesel
BoatingWilly
Has anyone had any experience with the 1/2 ton Dodge diesel? I am currently towing aprox. 5000 Lbs with a 2012 Hemi. Milage is generally poor (9-10 mpg) and the tranny shifts a lot. I would like to improve performance and milage and wondered if the 1/2 ton diesel would do both. Any thoughts would be appreciated.
47 REPLIES 47
Tystevens
Probably a pretty good match for that trailer, as long as the payload numbers are right.
You'll probably solve the frequent shifting issue. But not sure the mpg is going to be much better. Towing, at least. (I'll probably be lots better unloaded).
2008 Hornet Hideout 27B
2010 Chevy Suburban 1500 LT, Z71 package, 5.3/6A/3.42
2015 Ford F150 XLT Supercrew, 2.7 Ecoboost/6A/3.55 LS
Prior TVs:
2011 Ford F150 Ecoboost 3.5
2006 Chevy Silverado 2500HD Duramax LBZ
2005 Chevy Suburban 1500 4x4 LT, 5.3/4A/4.10
IdaD
I don't assume a 5000 lb trailer would cause issues for a half ton Ram, but yeah for sure check the payload and axle ratings. It would probably handle that size trailer really well. Not a ton of power, but good torque and I think it has an 8 speed.
You might also look into that new Titan XD. It looks like an interesting heavy-half option that should get better mileage than the big diesels.
2015 Cummins Ram 4wd CC/SB
Terryallan
Before you buy. Be sure to check out the payload. I have read the Ram 1500 diesel has very little. "some" are overloaded when you hookup with a empty truck. Seems diesels are pretty heavy.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
