Mar-23-2014 04:55 PM
Mar-25-2014 06:52 AM
oxygen wrote:
Not wanting to go outside this morning and check the valve, due to snow and cold, do you not need to open the valve cover or can you spray it into the opening ,the rod used to open the valve, the rod fits into?
Mar-25-2014 06:39 AM
Mar-25-2014 06:02 AM
Mar-24-2014 07:53 PM
Mar-24-2014 05:53 PM
Mar-24-2014 05:42 PM
brulaz wrote:
The new trailer has them stuck way up in the covered "basement". IIRC somebody here has managed to stick tubes up to the valves and use compressed air to force Silicone lube up onto the valves via the tubes.
Mar-24-2014 02:33 PM
Mar-24-2014 07:16 AM
path1 wrote:
OK not HI-tek don't laugh...
Salad oil or Mazola oil.
I know I didn't believe it either till I tried it. Long time Rv'er told us about this. Next time you empty tank do a good back flush to get everything out the best you can and add a jug.
Get a bottle of valve lube stuff and feel it between your fingers then do the same with some type of vegetable oil. See if you can tell the difference.
Mar-23-2014 08:36 PM
Mar-23-2014 05:27 PM
