โSep-30-2017 03:49 PM
โOct-01-2017 08:20 PM
tattoobob wrote:
If it's a standing pilot it should light even if the fan isn't running, if it's electronic ignition the fan should start then you should hear a clicking sound that's the pilot trying to start the burner
So if you have a standing pilot change the Thermocouple
If electronic check the fan or any safety switches could be a reset or bad switch also check the fan motor
โOct-01-2017 03:02 PM
โOct-01-2017 08:48 AM
โSep-30-2017 05:09 PM
work2much wrote:
While it's on the bench put 12 volts right across the fan and see if it will run. Many units same motor runs both interior and exterior fans on same spindle. Do the fans spin by hand?
โSep-30-2017 04:53 PM
โSep-30-2017 04:49 PM
โSep-30-2017 04:42 PM
work2much wrote:darsben1 wrote:
THERE is usually a sail switch that stops the main burner from igniting unless the fan is turning
Yes, this. No fan running, no burner ignition. First step is to repair fan. While you are in there you can test the sail switch for connectivity while in the on position.
โSep-30-2017 04:24 PM
โSep-30-2017 04:19 PM
โSep-30-2017 04:04 PM
