Easy way to raise trailer's nose while hitched in campground
profdant139
Fairly often, we pull into a campground space, only to discover that the nose of the trailer is just a little low, because of the way the pad is graded.
Rather than unhitch the trailer and raise the nose with the jack (which we prefer to avoid when we're just overnighting), here is an easier alternative: just raise the back of the tow vehicle by putting Lynx Levelers or some wood under the rear tires.
It's simple, but it works, as long as the nose is not way too low.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
19 REPLIES 19
opnspaces
Navigator II
Navigator II
I also just use the electric tongue jack to lift the tongue and the back of the vehicle as a unit. For extreme lifts I have just opened teh coupler and jacked it up.
But then again I never thought about just backing onto levelers. I might try it next time out as I always have a ton of room where I'm going.
Mike134
Since I use the tongue jack to lift the truck and trailer 6" to put on the equalizer spring bars, I just use the tongue jack and lift the trailer and truck the few inches needed to level it.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
BarabooBob
We just set up as usual and unhook. I just don't move the truck if it is an overnight and run in the morning stop. It only takes us about 5 minutes to hook up and do our safety check. By the way, we don't use a weight distribution system because our trailer is way below what the truck can actually tow. One of the advantages of towing a lightweight trailer.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Home_Skillet
Put air bags on the tow vehicle, along with the onboard air compressor. You can raise or lower the rear of the tow vehicle with the remote control.
LINK
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
RICK-ards_Red
I have seen people put wood down then back the truck onto the wood to raise the hitch. Seems to work. I have just left everything hooked up, WD, safety chains etc but undid the hitch pin and raise the tongue of the trailer. Then in the morning just lower the tongue onto the ball and leave , works for me.
2017 Coachman Catalina 25RKS
2015 GMC Sierra 1500 - Kodiak edition
