โJul-08-2013 05:32 PM
โJul-16-2013 04:51 PM
red31 wrote:
Reverse Battery Protection fuse - doesn't have a cute LED.
This fuse blows when the battery is connected backward
It is the 5th or bottom fuse
http://www.wfcoelectronics.com/Images/Products/OtherDocs/5-3.pdf
Charges @ 13.6v, not high enough for my 12v 'deep cycle'
โJul-16-2013 04:49 PM
RoyB wrote:
AS you notice if you want to be successful you have to do some planning and beefing up of systems and batteries.
Once you get setup it is a very pleasant way of camping. We only run our 2KW Honda generator for about three hours each morning and can run all the 120VAC items we want to run from a 600W PSW Inverter. We also run all of the 12VDC items we want to run which are direct connected to the battery bank. Our Battery bank is 255AHs capacity and it will drop down to around 12.0VDC by 8AM the next morning. This is when we want to connect the trailer 30A shore power cable to the 2KW Honda Generator 120VAC receptacle using the proper RV30A-15A long adapter (WALMART) and this allows the on-board converter/charger unit to re-charge our battery bank. Since we are using a smart-mode technology converter/charger this will re-charge our 255AH battery bank back to to its 90% charge state in as little as three hours of generator run time.
Where we camp here on the East side of the US most camp grounds and Natl Parks have generator run time restrictions in place and only a few hours during the day is allowed to run the generator. Never after 8PM at night...
OUr game plan was to decide what we wanted to have with us and beef-up the battery bank and system to do this in the one day/night run off the batteries and then re-charge back up to 90% charge state the next morning so we can do this all over again the next day/night battery run... This method does not do any harm to our batteries at all. However, we can only do this 50% to 90% charge state cycle for about 12-14 days when we must re-charge the batteries to their full 100% charge state which takes around 12-13 hours of generator run time to complete the charge cycle. Since we can never run the generators this long here on the East side of the US this is usually when we head for the house haha.. Watching the battery voltage drop from inside the trailer really helps us out keeping up with our approximate battery bank charge state.
Just passing along how we manage our batteries when camping off the power grid...
Roy Ken
โJul-13-2013 06:35 PM
โJul-13-2013 05:22 PM
โJul-09-2013 09:45 AM
โJul-09-2013 08:01 AM
โJul-08-2013 10:04 PM
rocelp wrote:
70 amp/hr
If I get the 2000 watt inverter, how much wattage in solar?
โJul-08-2013 09:12 PM
โJul-08-2013 08:53 PM
โJul-08-2013 07:57 PM
โJul-08-2013 07:49 PM
โJul-08-2013 07:29 PM
โJul-08-2013 06:50 PM
โJul-08-2013 06:47 PM
