Exterior Stove Vent Replacement Artic Fox 990
NVR2L82AV8
Evidently I've been down to many narrow brush and tree lined roads because during my fall camper inspection, in preparation for the winter camping season here in the desert, I noticed my exterior stove vent was cracked and looking inside I also noted the flapper was gone. You can even see the branch marks if you look close enough...ouch!
So, I ordered a new one. Once I got it I painted it for two reasons: 1. Get the color to match the sidewall white and, 2. Protect it since the other one yellowed over time.
Once I got the ten crews out I carefully tried to get a lever in between the exterior and the plastic vent.
Once I slowly unpryed it from the exterior I carefully scrapped of the sealant with a plastic edge. Next I got out the trusted razor blade a slowly moved it along to get off the adhesive. Not all came off.
Next, I got out the mineral spirits and begin to slowly unharden the sealant to get the surface as clean as new.
After that I pre-installed the new vent cover (notice the nice ivory white acrylic paint) to tape around the vent so when I get the dicor on I minimize the spillage and contamination over the camper side.
I then got my trusty pneumatic caulking gun (these things are worth their weight in gold) out and laid a big wide bead of Dicor on the surface of the wall and a tiny bead on the vent cover. I tried to be consistent where I put it down as it takes just a second to run the gun around this small area.
Lastly, I permanently mounted the vent cover and slowly and evenly tightened up the screws to prevent cracking the vent while pushing down the sealant inside. Once the screws were all tight I pulled up the tape and cha-ching!! Cleaned up the edges with a little spirits and it looks even better than it was new!!
2013 AF 990
2003 F350 6.0L 4X4 DRW, Oil bypass filter, Coolant Filter, Blue Spring fuel pressure mod, DELO ELC, DashBoss Bluetooth engine monitor, EGT/FP gauge, SuperSprings, torklift hitch/tiedowns, 48" SuperTruss, fastguns, Kenwood CMOS Backup Camera.
10 REPLIES 10
dakonthemountai
wnjj wrote:
dakonthemountain wrote:
Looks PERFECT! Good job! I did that on my old Weekender and when I bought my Lance I thought yay! I won't have to do that again... except that on my last trip the little levers that hold the outside flap closed disappeared... But I think I'll just fashion something on my own that is more reliable to hold it closed rather than replace the entire thing!
Dak
Here's what I did to latch the vent:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24397265.cfm
And here's what I did to fix the broken hinge:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28506892/gotomsg/28508392.cfm#28508392
I also painted with Krylon fusion.
OP: Nice work on the install. It looks great!
Great idea! Thanks!... I think I'll follow your lead on that!
Dak
2018 GMC Denali "Extreme" and 23' EVO 2050T Travel Trailer
Escapee member #224325-Since 1992
wnjj
Dak
dakonthemountai
Double post....
dakonthemountai
Dak
towpro
I swear I saw one made of metal once, I even think it was chrome plated. But I can't find where to buy it.
Mine is 1 year old and turning yellow.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
deltabravo
On my Desert Fox toy hauler, mine ended up looking like that too, after I smacked it with a pole mounted cleaning pad. I've been extra careful with that cleaning pad on my AF811. But, it's turning yellow now.... time for a paint job.
The frames on the door windows got painted about 4 years ago and they still look really nice.
Krylon Fusion
GeoBoy
Looks good. Why no butyl tape?
Bedlam
Moderator
Moderator
Mine has same chunk missing out of the hood but the flapper is fine. If it gets worse, I'll be doing the same.
Mattyd
Yup, pulled miine off, scuffed it up, cleaned it off and painted it as well. Need to do the upper window frame on my door and the two outside lights.
2016 AF 990
2013 Ram 3500 Dually, Crew Cab, 4x4 CTD
Hellwig Rear Anti-Sway Bar
Torklift StableLoads & Fastguns
2014 Rubicon Unlimited
CptnBG
looks good, I need to do the same thing.
'03 2500HD CrewCab SB 6.0 Gas 4x4
'04 Northstar Laredo SC
Bilsteins 5100
2014 1500 Silverado 5.3 Double Cab
1951 Chevy 3100
Formally OBXcamper
