Aug-10-2020 10:54 AM
Aug-31-2020 05:47 AM
Aug-30-2020 01:15 PM
4x4ord wrote:
Tests have been conducted on Agricultural tractors by Nebraska Tractor Tests and have shown that when 1/2 of rated HP is needed a tractor will burn nearly 30% less fuel running the engine at 80% rated engine rpm vs running at full rated rpm.
Aug-30-2020 01:06 PM
jdc1 wrote:
CVRA and ACTM stickers will probably be mandatory on the F450, as will stopping at scales in California.
Aug-30-2020 01:36 AM
Cummins12V98 wrote:Grit dog wrote:
So Ram 3500 or Ford 450??
Lol
I forgot what we were talking aboot. Thanks!
Aug-29-2020 07:28 PM
Lol
Aug-29-2020 01:53 PM
Aug-29-2020 12:52 PM
Aug-29-2020 10:44 AM
Aug-29-2020 10:17 AM
4x4ord wrote:
^^^^ Your right.... more fuel more torque. In order to burn fuel you need air. Read my post and think about it until you understand it. I'm not sure where you are actually disagreeing with me now?
Aug-29-2020 09:44 AM
Aug-29-2020 09:42 AM
Aug-29-2020 09:25 AM
4x4ord wrote:
You can increase an engine's displacement/torque by increasing bore, stroke, or number of pistons. The Cummins and Powerstroke are both 6.7 liter engines so will have similar cylinder pressure when they are making 1000 lbft of torque. Stroke vs bore makes no difference. Torque is a function of the fuel burned per revolution. Increasing the boost or the bore or the stroke puts more air in the cylinder to allow for more fuel to be injected. If you can burn 10% more fuel per revolution you should see about 10% more torque.
Aug-29-2020 08:28 AM
Aug-29-2020 08:20 AM
