โAug-10-2020 10:54 AM
โAug-22-2020 01:05 AM
โAug-21-2020 10:54 PM
โAug-21-2020 09:15 PM
โAug-21-2020 07:09 PM
โAug-21-2020 03:18 PM
โAug-19-2020 04:30 AM
NRALIFR wrote:
That was my experience as well when I bought my current truck.
I had a 2010 F450 King Ranch to trade, that we both loved except for the 6.4, so we were looking at KR F350 and 450 pickups. I recall that the price difference was less than $3000, and as far as I was concerned what I got for that 3K was well worth it. 19.5โs, bigger brakes, higher rated axles, tighter turning radius.
Maybe I SHOULD have bought the F350 instead, put 19.5โs on it, and just wished it had the rest.
Donโt need bigger brakes??? I think thatโs the first time Iโve ever heard that. You donโt need them till you do! Iโm always amused when someone tries to tell me what I NEED. In the end, only one of us is willing to write the check for MY needs. Thanks anyway, tho. ***Flush***
โAug-19-2020 03:54 AM
โAug-18-2020 08:14 PM
Cummins12V98 wrote:
Certainly didn't need a 450 for your 20k RV. My thought is you gained bigger brakes but NOT needed and tighter turning radius that honestly is not a reason to spend that much more $$$.
โAug-18-2020 09:25 AM
โAug-18-2020 05:08 AM
โAug-17-2020 10:46 PM
4x4ord wrote:
Yup. My 2017 Torqueshift 6r140 has a reverse ratio of 3.12 mated to a 3.55 rear end and 34" tires. The 10 speed has a reverse ratio of 4.7:1 so even if I stick with a SRW I'm not going to be backing trailers up at 35 mph much longer.
โAug-17-2020 08:34 PM
โAug-15-2020 08:26 PM
โAug-14-2020 10:44 AM
Cummins12V98 wrote:4x4ord wrote:
If I was going to get a Ford dually I would really wrestle with the f450. On the one hand I like the wide track front axle and 19.5 inch rims but on the other hand the 4.30 gear ratio would probably end up being a deal breaker for me even with the 10 speed. The Powerstroke has 1050 lbft of torque at 1600 rpm, Most rvers would be better off with 3.55 gears and settle for the f350 dually rather than have to run the 4.30 gears that come in the f450.
I am thinking as you are an "Alberta Guy" a RAM would look best wrapped around you.
โAug-14-2020 08:30 AM
