Sep-02-2019 02:57 PM
Sep-02-2019 09:10 PM
Sep-02-2019 09:00 PM
pianotuna wrote:
The problem with the calculation is the 80 watts is at the rated voltage of the panel. Unless it is an MPPT controller you won't "see" all of that. A rough approximation would be that around 60 watts may go into the battery bank.
That works out to about 300 watt-hours per day, or approximately 25 amp-hours.
But that is based on perfect conditions and tracking. So a real life number may be only 16 or 17 amp-hours per day for a fixed flat install.
Sep-02-2019 08:44 PM
Sep-02-2019 08:38 PM
Ed_Gee wrote:
Please, O please, someone point me to an 80 Watt solar panel that has a specification of 6 Amp output, as posted above. The best mono crystalline 80 Watt panel I can find can only output 4 Amps..... My Zamp 100W monocrystaline panels are only rated at 5.5 Amps.
Sep-02-2019 08:28 PM
Supercharged111 wrote:
In the summer, we have good sun angles and little cloud cover. That said, how can a guy record what a panel is putting out? We get beat hard with UV rays here, I have to wonder if the top of the skin isn't beat up and shielding some of those precious UV rays from creating useful electrons?
Sep-02-2019 08:25 PM
Sep-02-2019 08:01 PM
Sep-02-2019 07:57 PM
Ed_Gee wrote:work2much wrote:
. An 80 watt panel getting 6 hours of sun should make 30 amps or so of power a day. The vampire draw is probably in the 24 amp/day range or less..
No way an 80 Watt panel will provide 30Ah in a six hour sun day.....even under ideal conditions. Between clouds, sun angle, etc. he will be lucky to get 10 or 12 Ah......which a measly 1 Ah vampire draw will exceed over night.....and I would bet his vampire draw exceeds that. Yes, 160 Watts would probably be minimum he needs.
Sep-02-2019 06:38 PM
Sep-02-2019 06:28 PM
Sep-02-2019 04:55 PM
Sep-02-2019 04:29 PM
Sep-02-2019 03:23 PM
Sep-02-2019 03:19 PM
