fiberglass repair / BONDO?
modern_family
Will BONDO stick to fiberglass, I want to repair a small dent that is about 10" long and just deep enough to break the fiber glass. I want to make it flat and smooth as I will then add another "decal swoosh" over the repair to match the others on the back of the trailer, no one will ever know it was there.
I really dont want to deal with fiberglass if I don't have to.
Thanks
2017.. Prime Time Avenger. 32QBI
His.. 2011 F-350, King Ranch, 6.2L. Crew Cab, 4x4, 8' bed, SRW, 11,000 GVWR
Hers..2008 Ford Expedition, King Ranch Heavy Duty Tow, 3.73 gears
Sold.. 2005 Star craft, Travel Star 18SB
Sold.. 2013 Keystone Laredo, 291
11 REPLIES 11
Gonzo42
I tree jumped out and bit our RV on the side of the nose cone. Repair at CW in La Mirada was a beautiful job.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
wanderingbob
Oops , the only reason to use fabric is for strength ! If you are just filling a " dent " Bondo will do . If the glass is tore and flapping use cloth !
wanderingbob
Bondo is fiberglass, polyester resin with cabosil as filler . Same prep , same resin , different filler !
prichardson
I see that you are in Tampa; so you have a selection of marine supply stores to select from. Go to one of them and they will have the fiberglass repair materials that you need. If you have used Bondo you will have no problem with resin and gel coat.
campigloo
Bondo is not a really good match for fiberglass. Quit going to the big box stores and go to a specialty shop that sells to body shops. There is a product, forget the name of it, that is a mixture of fiberglass resin and ground, chopped or shredded fiberglass. Pick one depending on the extent of the damage. It spreads much like bondo, is sandable and water proof. Bondo will actually absorb moisture if not properly sealed and will not bond to fiberglass as well.
canoe_on_top
Fiberglass isn't too hard to work with. If you've done alright with Bondo, you shouldn't have any problem using glass. Just follow the directions.
modern_family
Thanks all... I didn't get as far as thinking about what type of paint. I will go to autozone and check out my choices. I guess since it is on the outdoor kitchen door, maybe it will see a little more "movement" than other areas. I am on the fence. I have never worked with fiberglass, but have used bondo many times. Seems like it is "6 to one, half dozen to another" hmmm...
dockmasterdave
Scuff sand and maybe apply some primer, and bondo should be fine. I'd prime and paint over it before putting the decal on. Spray can auto primer and paint should be fine. I'd go for it.
2014 F 150 ecoboost
2008 Chrysler Aspen
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
Bumpyroad
I have used white bondo on a boat console and on chips on the front of my motorhome. never had any "pop" off.
bumpy
AirForceAngler
It will pop off pretty quickly without the proper prep, especially if there's a crack underneath. Your best bet is to stop-drill the crack, rough sand the areas around the crack for adhesion, apply some fiberglass mat with resin, let this dry then sand it to feather it in and make as smooth as possible. Then just use a filler putty to smooth out for priming and painting.
2013 Toyota Tundra DoubleCab 4x4 iForce 5.7
2014 Grey Wolf by Forest River 26BH TT
oughtsix
Bondo does stick to fiberglass with proper surface prep. But I would use fiberglass resin and filler if it were me.
2006 Duramax Crew Cab Long Bed pickup.
2007 Coachman Captiva 265EX trailer.
