Gsragtop wrote:
One issue I have run into is the AC.. It was in the 90's today and we had a fully shaded spot, however even with the AC running all day it never hit below 80 in the trailer according to the furnace tstat. ... it's only a small 19 foot TT it should get it down into the 70's ??? ... it's a 8000 btu frididaire.
Also while we are at it, the fridge took forever to cool the drinks inside. I'm talking 6 hours or more.. Is that normal ??
It is all normal.
The 8000 BTU unit is probably working normally (you did say there was cool air coming out) but in reality it is too weak. My similarly sized previous RV (2010 Jayco 17Z) had a 13,500 BTU unit and that did the job nicely despite the tent ends which you don't have any which have/provide poor thermal insulation. You need a bigger AC for those temperatures, plain and simple.
As for the fridge - that is normal. Ammonia absorbtion fridges are not like house fridges and they are not as "powerful" at cooling down the insides. At the same time these RV fridges take a lot less power too so that is the reason they are used.
There are many things you can do to improve the fridge performance, however. One of the things I (and many others do) is precool the fridge on propane the night befoore leaving and then put things inside that were cool to begin with (from the house fridge). Also adding a small battery powered fan inside helps circulate the cool air away from the fins and throughout the cabinet. Some also install more efficient vent fans behind the fridge to the outside. This helps with thge evacuation of heat produced during the cooling of the fridge cabinet. Lastly you need to ensure that the side of the RV with the fridge does not see direct sun - that really hurts cooling.
In summary - AC needs upgrade, fridge you have to live with and learn to use better, with maybe some modifications.
My 2 cents.
