Freshwater Tank Removal
ThunderRock
I'm sure some of you have removed your freshwater tank. My reason is we have a seasonal parked at a cg, never use the freshwater tank, because we have running water.
A little more storage under the bed is what DW is after. Besides leaving the pump hooked up (for winterizing), what all do I disconnect to get it out? Doesn't seem like rocket science, but I'll take all the ideas & suggestions I can, LOL!
BTW, it's a 2000 Sunline Solaris. TIA.
Ken & Ruth
:B
'18 Keystone Hideout 232LHS - (Kuhrs' Kamping Korner)
Eaz-Lift WD & Sway System
Prodigy BC
'15 Chevy Colorado LT Ext Cab
'08 Dodge Dakota Crew Cab
7 REPLIES 7
Gene_Ginny
GaryWT wrote:
Most fresh water tanks are under the floor ...
Many of the Sunline Solaris line have the freshwater tank under the bed and above the floor like mine.
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
mobeewan
If you remove the water tank, make sure you remove the water pump too. sometimes the pump check valves go bad and the pumps leak back into the water tank. No tank big mess.
If you have to keep the pump for winterizing put a shut off valve at the pump outlet so you can isolate it from the city water pressure.
Or, Attach the pump to something (small cutting board) add a couple hoses with a female garden hose connection on the outlet hose, the other with no fitting and you can winterize though the city water inlet.
Muddydogs
Simple job, disconnect the tank fill line, drain line and water pump line then unbolt the tank from its mounts. Leave all the lines tucked away for easy replacement if or when you sell the RV.
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
Bumpyroad
is it removable and replaceable or do you have to destroy things to get it out?
where do you plan on storing the tank?
bumpy
bobndot
I would not remove it .
When I was a seasonal the transient guests would sometimes back into the water spigots causing the CG water pump to overheat and shut off. I had to use my partially filled water tank and pump in those situations, otherwise you might be stuck all covered in soap with no way to rinse off.
GaryWT
Most fresh water tanks are under the floor so there would not be added space if removed. If you do remove it you should hold onto it as at trade in time you might want it.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
Valkyriebush
I would not do that as you defeat the added purpose of our RV serving as an emergency option. I keep the fresh water tank full while at home and 1/2 when on the road. Leave your stuff at the seasonal CG instead as we do.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
