Fuse box
Pmacjoh1
Hello, I'm looking for help! I have a 1998 Artic FOX 22H. The Manuel states the fuse box is located in the electrical control center. But doesn't say where that is! Does anyone know where it is located?
Thanks
4 REPLIES 4
enblethen
OP found his panel!
He posted finding it under couch.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Guy_Roan
Go outside and see where your feed cord comes in and the panel should be fairly close to there.
Guy
Pmacjoh1
Ok, found it! The circut board & fuse box is under the jackkife sofa.
Thanks!
enblethen
Should have a small panel with 120 volt circuit breakers. The 12 volt fuses are located next to them behind small metal plate held on with thumb screw.
Bud
USAF Retired
Pace Arrow
