โAug-14-2017 09:46 AM
โAug-15-2017 08:43 AM
โAug-14-2017 08:03 PM
โAug-14-2017 06:53 PM
โAug-14-2017 03:02 PM
....when I try to plug anything in, it flips the generator breakerThis would typically indicate that there is something 120V that is miswired.
โAug-14-2017 12:04 PM
pattycamper wrote:
I have a meter, but all I have tested with it is batteries ๐ I will google how to test breaker. I flipped all breakers back and forth, so I don't think they are issue as far as not being reset. Fuses aren't blowing anymore, just first time issue started. When I was trouble shooting last time, it was after 3 day trip and camper was in street with no AC in 110 degrees. I had to stop because I was about to pass out. I'm not certain if any AC is working at this point. If I remember correct, by the time the generator breaker started flipping after replacing GFI, NONE of the plugs, GFI or otherwise worked. Initially my other non-gfi outlets were working. I could have been a bit delusional at the end of this before I put it in storage ๐ I will test breakers as soon as I can get back to trailer. I recently replaced the 30amp breaker (it dry rotted apart) that the battery lines go through at front of trailer where battery connects. Any chance this could be part of issue. It was working, but maybe it blew?
Patty
โAug-14-2017 11:13 AM
gmw photos wrote:
Personally I hate it when folks come on to these forums and suggest rookies grab a multimeter and start poking around. Truth is, do it wrong and you can die from electrocution.
If someone is going to suggest to another to get a multimeter, the first thing they should suggest is the new person get instructions on the safe use of it from a qualified individual.
Electricity is infinitely patient.....just waiting for you to screw up so it can bite you.
โAug-14-2017 10:50 AM
โAug-14-2017 10:40 AM
โAug-14-2017 10:13 AM
Bud
USAF Retired
Pace Arrow
โAug-14-2017 10:06 AM
โAug-14-2017 09:58 AM
