Glueing EPDM in the cold
wvabeer
I am getting new roofing and plan on installing it in 40 / 50 degrees, the latex glue says 50 and up has anyone run into trouble doing it at these temps?
1999 Dutch Star DP3884
2015 Camplite 6.8C
2012 Cherokee 39L destination
2022 F350 XL 4x4
07 FLHRS
8 REPLIES 8
wvabeer
Now after I get the gutters on can I use dicor self leveling and ADCO edge sealant to finish sealing everything with temps in the 30's ?
2015 Camplite 6.8C
2022 F350 XL 4x4
07 FLHRS
westend
wvabeer wrote:
Is there an easy way to get the old puddy tape off of the gutter trim?
Wire wheel on a right-hand grinder, followed up by mineral spirits.
'03 F-250 4x4 CC
wvabeer
2015 Camplite 6.8C
2022 F350 XL 4x4
07 FLHRS
wvabeer
Its going to be 48 Sunday I was hopeing to get it down after I resheet it Saturday with 7/16 OSB.
2015 Camplite 6.8C
2022 F350 XL 4x4
07 FLHRS
Steve_S1
Keep your products in a warm room before use and you'll have no problems with applying it. Have a torch on hand to warm any bends you run into.
I've applied miles of this in B.C winters and I've never had any issues.
2010 Cougar 25RL
newman_fulltime
You need to build a tent over the trailer get a coule torpedo heaters get it warmthen put the roofing down
wvabeer
donn0128 wrote:
Glue is not going to be your problem. It is the material that is going to be a pain. When it is cold the rubber, yea i know, is going to be very stiff making it extremely difficult to get laid flat and smooth. You will be much better off waiting until the temps are in the 70's before you attempt to lay it.
I never thought about that and the rubber is going to be 90 mil even more hard to work with. Maybe heat the roll up? I gotta figure a way to do it. All I have is a big waterproof tarp covering it
2015 Camplite 6.8C
2022 F350 XL 4x4
07 FLHRS
donn0128
