I was doing to go to 225s from my 205s but the wheel wells looked very close.
Though I would have like to have measure the width and hieght of the two tire mounted and inflated on a a rim, I could not find any place to do that. It seemed a bit odd to crawl in the snow at the local RV dealer.
However if you can do that, you can determine if you have enough room in your wheel wells.
Instead, I had to settle for a set of "D" rated 205s. They are inflated to 65 lbs.
The tires I replaced were the 7 year old "C" rated 205 tires installed at the factory. I had put 15,000 miles on them plus whatever the previous owner added.
We will give these new ones a good road test when we go to Arizona next month.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
