โJun-03-2014 06:38 AM
โJun-03-2014 10:17 AM
โJun-03-2014 10:00 AM
โJun-03-2014 07:54 AM
โJun-03-2014 07:40 AM
Nwatkins176 wrote:You need to check with your trailer manufacturer to make sure they won't void the warranty if you install a gooseneck adapter. This kind of hitch puts a LOT more strain on the fiver frame which may not be designed to take it.
Hello everybody. I just now bought a tow vehicle for my 36' 5er toy Hauler, 15k loaded and 3k pound hitch weight. I got an Tundra.... Just kidding got a 2011 RAM 3500 DRW. The truck already has a goose neck hitch installed. I know there are plenty of adapters to hitch my 5er to the goose neck and even a new king pin to turn my 5th wheel into a goose. My question is since I don't and probably won't be towing a goose neck can I use one of these adapters as a permanent solution or would I be better off putting a 5th wheel hitch in the truck. What is your opinion. Thanks for the help. Bare with me as this is my first 5er and still learning about the hitches.
โJun-03-2014 07:28 AM
โJun-03-2014 07:12 AM
Nwatkins176 wrote:i have pulled many horse trailers with gooseneck hitches and had a 5r with a goose neck conversion. goose neck is the only way to go. i don't know why all 5rs aren't made with the goose neck hitches. i had a fold down ball in my last f350 that gave full use of the bed. if i got another 5r it would have a goose neck conversion. some 5rs may not be built heavy enough to handle the front to rear added stress. mine worked fine.
โJun-03-2014 07:05 AM
n7bsn wrote:
On of the advantages of say the B&W is how easy it is to remove the hitch and leave a clean bed for hauling stuff in the truck
Not so easy with a regular hitch
โJun-03-2014 06:55 AM
